• GPU RTX 3050 ti
• DS 6.3
• NVIDIA GPU Driver Version 535
• New Requirement
I am intergrating 3d action recognition app(2d pretrained model) with deepstream app/test5 as sgie, primary model as person detector and secondary as action recognition. I added custom output parser function from action recognition app to deepstream app sgie(as a probe), but no secondary classfications coming
Main config file
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=5
[tiled-display]
enable=1
rows=2
columns=2
width=1280
height=720
gpu-id=0
nvbuf-memory-type=0
[source0]
enable=1
type=3
uri=file:///media/sameer/Extras/deepstream-6.3/samples/streams/sample_walk.mov
num-sources=1
gpu-id=0
cudadec-memtype=0
[source1]
enable=1
type=3
uri=file:///media/sameer/Extras/deepstream-6.3/samples/streams/sample_run.mov
num-sources=1
gpu-id=0
cudadec-memtype=0
[sink0]
enable=1
type=2
sync=1
source-id=0
gpu-id=0
nvbuf-memory-type=0
[osd]
enable=1
gpu-id=0
border-width=1
text-size=15
display-text=1
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Serif
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=0
[streammux]
gpu-id=0
live-source=0
batch-size=4
batched-push-timeout=40000
width=1920
height=1080
enable-padding=0
nvbuf-memory-type=0
[primary-gie]
enable=1
gpu-id=0
input-tensor-meta=0
batch-size=4
bbox-border-color0=1;0;0;1
bbox-border-color1=0;1;1;1
bbox-border-color2=0;0;1;1
bbox-border-color3=0;1;0;1
interval=0
gie-unique-id=1
nvbuf-memory-type=0
config-file=config_infer_primary.txt
[secondary-pre-process0]
enable=1
operate-on-gie-id=1
config-file=///media/sameer/Extras/deepstream-6.3/sources/apps/sample_apps/deepstream-app-3daction/config_preprocess_2d_custom.txt
[tracker]
enable=1
respectively
tracker-width=960
tracker-height=544
ll-lib-file=/opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so
ll-config-file=config_tracker_NvDCF_perf.yml
gpu-id=0
display-tracking-id=1
[secondary-gie0]
enable=1
gpu-id=0
input-tensor-meta=1
batch-size=4
gie-unique-id=2
operate-on-gie-id=1
operate-on-class-ids=1;2;3;4
config-file=///media/sameer/Extras/deepstream-6.3/sources/apps/sample_apps/deepstream-app-3daction/config_infer_primary_2d_action.txt
[tests]
file-loop=0
preprocess config
[property]
enable=1
target-unique-ids=2
# 0=process on objects 1=process on frames
process-on-frame=0
# network-input-shape: batch, channel x sequence, height, width
network-input-shape= 4;192;224;224
network-input-shape= 4;96;224;224
# 0=RGB, 1=BGR, 2=GRAY
network-color-format=0
# 0=NCHW, 1=NHWC, 2=CUSTOM
network-input-order=2
# 0=FP32, 1=UINT8, 2=INT8, 3=UINT32, 4=INT32, 5=FP16
tensor-data-type=5
tensor-name=input_rgb
processing-width=224
processing-height=224
# 0=NVBUF_MEM_DEFAULT 1=NVBUF_MEM_CUDA_PINNED 2=NVBUF_MEM_CUDA_DEVICE
# 3=NVBUF_MEM_CUDA_UNIFIED 4=NVBUF_MEM_SURFACE_ARRAY(Jetson)
scaling-pool-memory-type=0
# 0=NvBufSurfTransformCompute_Default 1=NvBufSurfTransformCompute_GPU
# 2=NvBufSurfTransformCompute_VIC(Jetson)
scaling-pool-compute-hw=0
# Scaling Interpolation method
# 0=NvBufSurfTransformInter_Nearest 1=NvBufSurfTransformInter_Bilinear 2=NvBufSurfTransformInter_Algo1
# 3=NvBufSurfTransformInter_Algo2 4=NvBufSurfTransformInter_Algo3 5=NvBufSurfTransformInter_Algo4
# 6=NvBufSurfTransformInter_Default
scaling-filter=0
tensor-buf-pool-size=8
custom-lib-path=/opt/nvidia/deepstream/deepstream/lib/libnvds_custom_sequence_preprocess.so
custom-tensor-preparation-function=CustomSequenceTensorPreparation
[user-configs]
channel-scale-factors=0.007843137;0.007843137;0.007843137
channel-mean-offsets=127.5;127.5;127.5
stride=1
subsample=0
#[group-0]
#src-ids=0;1
#process-on-roi=0
#roi-params-src-0=0;0;1500;720
#roi-params-src-1=0;0;1500;720
#roi-params-src-2=0;0;1280;720
#roi-params-src-3=0;0;1280;720
[property]
gpu-id=0
tlt-encoded-model=/media/sameer/Extras/deepstream-6.3/sources/apps/sample_apps/deepstream-test5-3daction/resnet18_2d_rgb_hmdb5_32.etlt
tlt-model-key=nvidia_tao
#model-engine-file=/media/sameer/Extras/deepstream-6.3/sources/apps/sample_apps/deepstream-app-3daction/resnet18_2d_rgb_hmdb5_32.etlt_b4_gpu0_fp32.engine
labelfile-path=/media/sameer/Extras/deepstream-6.3/sources/apps/sample_apps/deepstream-app-3daction/labels.txt
batch-size=4
process-mode=2
input-tensor-from-meta=1
network-mode=2
gie-unique-id=2
network-type=1
output-tensor-meta=1
tensor-meta-pool-size=8
