• Hardware Platform: GPU, RTX 4080 Laptop, 12G
• DeepStream Version: 7.0
• TensorRT Version: 8.6.1.6
• CUDA Version: 12.2
• NVIDIA GPU Driver Version: 555.42.02
• Issue Type: bug
I’m interested in 3D Sensor Fusion and started with with DeepStream-3D Sensor Fusion Multi-Modal Application and Framework — DeepStream documentation 6.4 documentation
I’ve installed all the required environment (on Ubuntu 24.04.4 LTS), managed to run the triton server, but got an error when tried to run a deepstream 3d sensor fusion pipeline with bevfusion config:
$ bevfusion/docker_run_ds3d_sensor_fusion_bevfusion_pipeline.sh ds3d_lidar_plus_multi_cam_bev_fusion.yaml
The error is:
lidarinference_filter_impl.cpp:204, INFO: lidarinference datafilter is starting to filter datamap
gl_cuda_utils.cpp:43, ERROR: register gl texture into cuda failed, cuda err_no:999, err_str:cudaErrorUnknown
gl_texture_render.cpp:177, ERROR: Failed to register texture to cuda, check failure
gl_texture_render.cpp:203, ERROR: allocate texture failed for texture3d render, check failure
gl_texture_render.cpp:310, ERROR: Failed to upload image into texture3d., check failure
gles_3d_ensemble_render_impl.cpp:125, ERROR: upload datamap into Gl failed., check failure
glfw_window.cpp:347, ERROR: user GL render failed, check failure
gles_3d_ensemble_render_impl.cpp:63, ERROR: glwinow run failed.
nvds3d_gst_plugin.cpp:167, ERROR: datarender error: GLwindow run failed
/dvs/git/dirty/git-master_linux/deepstream/sdk/src/utils/ds3d/gst/nvds3d_pipeline_context.h:329, ERROR: ERROR from element ds3d_sensor_fusion_render: appsink Failed to stream due to ds3d errors, details: nvds3d_gst_plugin.cpp(168): NotifySinkError (): /GstPipeline:DeepStreamSensorFusionApp/GstBin:ds3d_sensor_fusion_render/GstAppSink:ds3d_sensor_fusion_render:
appsink error: GLwindow run failed
What’s the reason of this error and how to solve? Thanks.
