[application]
enable-perf-measurement=1
perf-measurement-interval-sec=5
#gie-kitti-output-dir=streamscl
[tiled-display]
enable=1
rows=1
columns=1
width=1280
height=720
gpu-id=0
nvbuf-memory-type=0
[source0]
enable=0
#Type - 1=CameraV4L2 2=URI 3=MultiURI
type=3
#uri=file:///home/jetson/workspace/deepstream_sdk_v4.0.2_jetson/samples/streams/sample_720p.mp4
uri=file:///home/jetson/workspace/testshanghai_720p.mp4
#drop-frame-interval=10
num-sources=1
gpu-id=0
nvbuf-memory-type=0
[source1]
enable=0
type=3
#uri=file:///home/jetson/workspace/deepstream_sdk_v4.0.2_jetson/samples/streams/sample_1080p_h264.mp4
uri=file:///home/jetson/workspace/testbeijing_720p.mp4
#drop-frame-interval=2
num-sources=1
gpu-id=0
nvbuf-memory-type=0
[source2]
enable=1
type=2
uri=rtsp://admin:HadoopAdmin@192.168.1.108
num-sources=1
gpu-id=0
nvbuf-memory-type=0
[sink0]
enable=0
#Type - 1=FakeSink 2=EglSink 3=File
type=2
sync=0
source-id=0
gpu-id=0
nvbuf-memory-type=0
[sink1]
enable=0
#Type - 1=FakeSink 2=EglSink 3=File 4=UDPSink 5=nvoverlaysink 6=MsgConvBroker
type=6
msg-conv-config=dstest5_msgconv_sample_config.txt
#(0): PAYLOAD_DEEPSTREAM - Deepstream schema payload
#(1): PAYLOAD_DEEPSTREAM_MINIMAL - Deepstream schema payload minimal
#(256): PAYLOAD_RESERVED - Reserved type
#(257): PAYLOAD_CUSTOM - Custom schema payload
msg-conv-payload-type=0
msg-broker-proto-lib=/opt/nvidia/deepstream/deepstream-4.0/lib/libnvds_kafka_proto.so
#Provide your msg-broker-conn-str here
msg-broker-conn-str=192.168.31.109;9092;vehicle
topic=vehicle
#Optional:
msg-broker-config=…/…/deepstream-test4/cfg_kafka.txt
[sink2]
enable=0
type=3
#1=mp4 2=mkv
container=1
#1=h264 2=h265 3=mpeg4
codec=1
sync=0
bitrate=4000000
output-file=out.mp4
source-id=0
[sink3]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File 4=RTSPStreaming
type=4
#1=h264 2=h265
codec=1
sync=1
qos=1
bitrate=4000000
rtsp-host=192.168.1.12
rtsp-port=8554
udp-port=5400
#Do Not Disable On Screen Display
[osd]
enable=1
gpu-id=0
border-width=2
text-size=10
text-color=1;1;0.2;1;
text-bg-color=0.3;0.3;0.3;0.5
font=Arial
show-clock=1
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=0
[streammux]
gpu-id=0
##Boolean property to inform muxer that sources are live
live-source=0
batch-size=1
##time out in usec, to wait after the first buffer is available
##to push the batch even if the complete batch is not formed
batched-push-timeout=40000
width=1280
height=720
##Enable to maintain aspect ratio wrt source, and allow black borders, works
##along with width, height properties
enable-padding=0
nvbuf-memory-type=0
[primary-gie]
enable=1
gpu-id=0
#Required to display the PGIE labels, should be added even when using config-file
#property
batch-size=1
bbox-border-color0=1;0;0;1
bbox-border-color1=0;1;1;1
bbox-border-color2=0;0;1;1
bbox-border-color3=0;1;0;1
interval=0
#Required by the app for SGIE, when used along with config-file property
gie-unique-id=1
nvbuf-memory-type=0
model-engine-file=…/…/…/…/…/samples/models/Primary_Detector_Nano/resnet10.caffemodel_b8_fp16.engine
labelfile-path=…/…/…/…/…/samples/models/Primary_Detector_Nano/labels.txt
config-file=…/…/…/…/…/samples/configs/deepstream-app/config_infer_primary.txt
#infer-raw-output-dir=…/…/…/…/…/samples/primary_detector_raw_output/
[tracker]
enable=1
tracker-width=480
tracker-height=272
ll-lib-file=/opt/nvidia/deepstream/deepstream-4.0/lib/libnvds_mot_iou.so
#ll-lib-file=/opt/nvidia/deepstream/deepstream-4.0/lib/libnvds_mot_klt.so
#ll-lib-file=/opt/nvidia/deepstream/deepstream-4.0/lib/libnvds_nvdcf.so
#ll-config-file required for DCF/IOU only
#ll-config-file=tracker_config.yml
#ll-config-file=iou_config.txt
gpu-id=0
#enable-batch-process applicable to DCF only
enable-batch-process=0
