Nano Jetson
• DeepStream Version
SDK 4.02
4.3
Hello ,
I am trying to stream video from Logitech 930e camera and its working.
The problem is that the stream that i get in client side (e.g : VLC ) shows a degradation in the video quality.
What can be the reason ?
This is my deepstream_app_config_yoloV3_tiny.txt configuration :
Under deepstream_sdk_v4.0.2_jetson\sources\objectDetector_Yolo
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI
type=1
#uri=file://../../samples/streams/sample_1080p_h264.mp4
uri=file:out.mp4
num-sources=1
gpu-id=0
(0): memtype_device - Memory type Device
(1): memtype_pinned - Memory type Host Pinned
(2): memtype_unified - Memory type Unified
cudadec-memtype=0
camera-width=1920
camera-height=1080
camera-fps-n=30
camera-v4l2-dev-node=0
camera-fps-d=1
#num-extra-surfaces=10
[sink0]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File 4=RTSPStreaming
type=4
#1=mp4 2=mkv
container=2
#1=h264 2=h265 3=mpeg4
gpu-id=0
nvbuf-memory-type=0
#only mpeg4 is supported right now.
codec=1
sync=0
bitrate=4000
set below properties in case of RTSPStreaming
rtsp-port=8554
udp-port=5400
[source0]
enable=1
type=1
uri=file:out.mp4
num-sources=1
gpu-id=0
cudadec-memtype=0
camera-width=1920
camera-height=1080
camera-fps-n=30
camera-fps-d=1
[sink0]
enable=1
type=4
#1=mp4 2=mkv
container=2
gpu-id=0
nvbuf-memory-type=0
codec=1
sync=0
bitrate=4000
rtsp-port=8554
udp-port=5400
