Deepstream 5.0 docker xecution program prompt"munmap_chunk(): invalid pointer"
jetson nano
ds5.0
jetpack 4.4 GA
Inside ds5.0 docker, if I execute my code, the following error will be prompted:
But when I execute it on the host, there will be no such problem. Is there a problem in my environment?
can you run DS samples in the docker?
The sample_apps/deepstream-app program can be run normally!
can you share the repo code?
Sorry for taking so long to reply to you, I solved my problem through some debugging, but I want to consult, my host version is “# R32 (release), REVISION: 4.2, GCID: 20074772, BOARD: t210ref, EABI : aarch64, DATE: Thu Apr 9 01:22:12 UTC 2020” is jetpack4.4DP, my docker image download is “nvcr.io/nvidia/deepstream-l4t:5.0-20.07-samples”, I compared the The size of the so file in /opt/nvidia/deepstream/deepstream-5.0/lib/ of deepstream 5.0sdk under the host is different from the /opt/ directory in the docker container I downloaded. Is this normal?
nvcr.io/nvidia/deepstream-l4t:5.0-20.07-samples” is DeepStream5.0GA docker, it must run on Jetpacl4.4GA release, which version (cat /etc/nv_tegra_release) is “# R32 (release), REVISION: 4.3, GCID: 21589087, BOARD: t186ref, EABI: aarch64, DATE: Fri Jun 26 04:34:27 UTC 2020”
Then, does the container version have deepstream 5.0DP?
Under https://ngc.nvidia.com/catalog/containers/nvidia:deepstream-l4t/tags , you can find some docker images with " 5.0-dp", they are for DP.
However, I would like to recommend you to upgrade to GA to avoid any known issue.
