• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version 5.1
• TensorRT Version 11.2
• NVIDIA GPU Driver Version (valid for GPU only) 460.32.03
Hi @happo , it seems that you have 30 h265 sources and mainly the decoder occupies the CPU.
Cause I do not have your stream, So could you help to have a simple test in your env?
1.Save your stream to a mp4 file(you can also give that file to us)
2.Modify the config file blow simply:
My config set “rtsp-reconnect-interval-sec=30”
I found too many of the 30 rtsp sources lost data, the “g_timeout_add" func will stock loop thread.
Then cpu usage increased.
