• DeepStream Version = 5.1
• NVIDIA GPU Driver Version - CUDA = 11.1
I am using the following add_del_multisources with 4 rtsp sources and have set streamdemux to sink 4 individual rtsp-out servers.
This custom pipeline:
This used to working in docker = 5.1-21.02-devel but now I get an error:
Please suggest any solutions!
What do you mean? Do you mean c/c++ sample works but python sample failed?
I’m running c/c++ compiler based on c/c++ samples add_del_sources . I’ve customized it.
Do you think the failure is caused by deepstream by not what you changed?
I run successful without streamdemux but not with added streamdemux .
There is nvstreammux in the sample. Please check your code to find out what is the difference and why the error happens.
Yes, I did.
Can you check my pipeline?
deepstream_muxe.c (5.3 KB)
I solved the error "Segmentation fault (core dumped). But I’m now facing to unable read rtsp-out server. In this pipeline, I enter source_id and uri value from keyboard.
main-pipeline:
streammux → nvvidconv → nvosd → streamdemux → udpsink_bin
udpsink-bin:
queue → nvvidconv → cap-filter(“video/x-raw, format=I420”) —> encoder(nvv4l2h264enc) → rtppay → sink (“udpsink”)
This my code
deepstream_custom_add_del_2.c (18.5 KB)
While processing add_del
Please suggest any solution!
Amycao
October 25, 2021, 12:38pm
10
Did this still be an issue?
Thanks your response.
I’ve not resolved this problem, I’ve a break from other work.
Amycao
October 26, 2021, 9:22am
12
At a first glance, you did not connect streammux and source.
I worked add_del custom + save filesink ( my issue , I just custom filesink → udpsink ).
After the first step add-source, I get link streammux and source at main . Other steps, when adding a source from the keyboard, I use function add_sources which has get_request_pad (streammux, pad_name ) .
This my update code
deepstream_custom_add_del_rtsp.c (20.2 KB)
Amycao
October 27, 2021, 6:05am
14
You still did not connect nvstreammux with source, the element before it, You can refer to any sample about this.
Thanks for your response, I can resolve my problem which is rtsp-out error.
system
Closed
November 16, 2021, 9:09am
17
