Deepstream 6.0.1 on Jetson Xavier NX with Triton Python backend
Is it possible to run Deepstream 6.0.1 on Jetson Xavier NX with Triton using the Python backend? The features table in the docs Gst-nvinferserver — DeepStream 6.0 Release documentation do not indicate if it’s compatible.
I’m trying to take a model’s output and run custom python pre-processing logic before passing this as input to another model. Can this scenario be done on the Jetson Xavier NX with Deepstream using the Triton python backend?
• DeepStream Version
• TensorRT Version
could you elaborate your custom python pre-processing logic? nvinferserver supports to do preprocess, you only need to modify configuration file. please refer to deepstream sample deepstream\samples\configs\deepstream-app-triton\source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt, it assembles 3 models, the first one detects vehicles, the following models check vehicletypes, color, carmake.
In addition to custom pre-processing, we also need to use our own custom model architecture.
deepstream nvinferserver plugin will leverage opensource lib triton to do inference, triton supports custom model architecture, please refer to Gst-nvinferserver — DeepStream 6.2 Release documentation
