Deepstream 6.0 Cannot get ObjectMeta Parent Object in deepstream_lpr_app
• Hardware Platform (Jetson / GPU) : Jetson
• DeepStream Version : 6.0
• JetPack Version (valid for Jetson only): 4.6
• TensorRT Version : 8.0
• Issue Type( questions, new requirements, bugs): questions/bugs
I have tried to compile and run deepstream_lpr_app with deepstream 6.0
In deepstream-lpr-app/deepstream_lpr_app.c, there is a part of code which getting the parent object from the LPDNet inference result
if (obj_meta->unique_component_id == SECONDARY_DETECTOR_UID) {
  if (obj_meta->class_id == SGIE_CLASS_ID_LPD) {
    lp_count++;
    /* Print this info only when operating in secondary model. */
    if (obj_meta->parent)
      g_print ("License plate found for parent object %p (type=%s)\n",
        obj_meta->parent, pgie_classes_str[obj_meta->parent->class_id]);
In Deepstream 6.0 I cannot get the parent, which the obj_meta->parent is always None
However in Deepstream 5.1 (Both Jetpack 4.6 & 4.5.1) I can get it without any issue.
Suppose the parent will be set in SGIE nvinfer. nvinfer is open source code. Can you have a try to add some log to trace it?
Sorry I have no idea. Can you tell me which part of the source code? Are you referring to Nvinfer.h in TensorRT source code?
nvinfer plugin source code.
I have tried to move osd_sink_pad_buffer_probe into different position of the pipeline, and I found that
it can get the parent object all the way until the nvtile sink pad. If I attach the probe to the src pad of nvtile, I cannot get the parent object.
If I attempt to remove the tiler from the pipeline, that this will happen at the nvvidconv element.
The pipeline of LPR app should be like following:
streammux -> primary_detector -> tracker -> secondary_detector -> secondary_classifier -> nvtile -> nvvidconv -> nvosd -> sink
I guess the issue is not in nvinfer
Great! do you still has any issue in your use case?
I can use a walk-around in my use-case, but I think it would be great if I can access the parent object at nvdsosd src pad.
If it is not a desired behaviour in deepstream 6.0 hope that It will be solved in some day
