Deepstream 6.0 container - File does not exist: OpenCV is required to run INT8 calibrator
I am trying to convert my yolo model to int8 engine for deepstream container but having an issue with opencv INT8 calibrator does not exist.
I have installed opencv in the container by using the standard apt-get
apt install libopencv-dev python3-opencv
Still have the same issue.
Any ideas on how to solve this?
Which sample do you use?
Are you using the sample from marcoslucianops?
I am using this container nvcr.io/nvidia/deepstream-l4t:6.0-samples for the Jetson NX. I docker run and mount a drive as a volume so I can copy the calibration images/txt and custom model.
  git clone https://github.com/marcoslucianops/DeepStream-Yolo.git /opt/nvidia/deepstream/deepstream/sources/DeepStream-Yolo
  cd /opt/nvidia/deepstream/deepstream/sources/DeepStream-Yolo
  /bin/bash -c 'CUDA_VER=10.2 make -C nvdsinfer_custom_impl_Yolo'
  cp -r /usr/src/app/calibration calibration
  cp /usr/src/app/calibration.txt
  cp /usr/src/app/calibration.txt .
  apt update
  apt-get install libopencv-dev python3-opencv
  export INT8_CALIB_IMG_PATH=calibration.txt
  export INT8_CALIB_BATCH_SIZE=1
  cp /usr/src/app/models/yolov8/yolov8n.wts .
  cp /usr/src/app/models/yolov8/yolov8n.cfg .
  cp /usr/src/app/models/yolov8/labels.txt .
  apt install nano
  nano deepstream_app_config.txt
  nano config_infer_primary_yoloV8.txt
  deepstream-app -c deepstream_app_config.txt
Output after running command.
Total number of YOLO layers: 299
Building YOLO network complete
Building the TensorRT Engine
NOTE: letter_box is set in cfg file, make sure to set maintain-aspect-ratio=1 in config_infer file to get better accuracy
File does not exist: /opt/nvidia/deepstream/deepstream-6.0/sources/DeepStream-Yolo/calib.table
deepstream-app: yolo.cpp:98: nvinfer1::ICudaEngine* Yolo::createEngine(nvinfer1::IBuilder*, nvinfer1::IBuilderConfig*): Assertion `0' failed.
Aborted (core dumped)
The modification to the configuration files.
deepstream_app_config.txt - I also set to fakesink.
[primary-gie]
enable=1
gpu-id=0
gie-unique-id=1
nvbuf-memory-type=0
config-file=config_infer_primary_yoloV8.txt
config_infer_primary_yoloV8.txt - I only have 5 classes
custom-network-config=yolov8n.cfg
model-file=yolov8n.wts
model-engine-file=model_b1_gpu0_int8.engine
int8-calib-file=calib.table
labelfile-path=labels.txt
batch-size=1
network-mode=1
num-detected-classes=5
Which JetPack version do you use?
It’s expected that Deepstream 6.0 image works with JetPack 4.6 GA.
I am using Jetpack 4.6. I will try it on a dev board than an industrial board.
There is no “calib.table” in the original configuration DeepStream-Yolo/config_infer_primary_yoloV8.txt at master · marcoslucianops/DeepStream-Yolo (github.com), why do you change the configuration?
This sample is not provided by Nvidia, please contact the author for resolution.
