DeepStream 6.0 deepstream_rt_src_add_del.py Bug
I tried running deepstream_rt_src_add_del.py with a single RTSP stream as the input.
I did not make any modifications to the source code provided via GitHub but I get the following error after a few moments
Creating Pipeline
Creating streammux
Creating source_bin  0
Creating uridecodebin for [rtsp://<link>]
source-bin-00
Creating Pgie
Creating nvtracker
Creating tiler
Creating nvvidconv
Creating nvosd
Creating EGLSink
Atleast one of the sources is live
Adding elements to Pipeline
Linking elements in the Pipeline
Now playing...
1 :  rtsp://<link>
Starting pipeline
Calling Start 2
source-bin-02
Decodebin child added: source
STATE CHANGE NO PREROLL
Calling Start 3
source-bin-03
Calling Start 1
source-bin-01
Calling Stop 2
STATE CHANGE SUCCESS
sink_2
  File "deepstream_rt_src_add_del.py", line 218, in delete_sources
    stop_release_source(source_id)
  File "deepstream_rt_src_add_del.py", line 168, in stop_release_source
    sinkpad.send_event(Gst.Event.new_flush_stop(False))
AttributeError: 'NoneType' object has no attribute 'send_event'
I was wondering if I can get any assistance with regards to this issue.
Update: I notice that on the streammux, there is no sink_%u % source_id via the following check:
# output: src
# FYL streammux.pads contains only the source pad and no sink pads,
# hence we get a value of None when we call the following code:
# streammux.get_static_pad(pad_name)
print(f'pad name: {streammux.pads[0].name}')
# Contains only one element (we need to add sink pad)
print(f'pad list: {streammux.pads}')
Specs
• Hardware Platform (Jetson / GPU): dGPU
• DeepStream Version: 6.0
• TensorRT Version: 8.01
• NVIDIA GPU Driver Version (valid for GPU only): 470.57.02
Best regards,
Jay
I managed to fix the issue. FYI, for whoever comes across this, is it just me or does deepstream_rt_src_add_del.py GitHub Link not work right out of the box?
Thanks for the update, will have team to check this issue.
I think there might have been some other unaccounted variable / factor.
To double check, I tried reproducing the issue on a different machine and for some reason, the pipeline works fine on that device.
If the reproduction was successful, then great!
Otherwise, I wanted to let you know in case you are having trouble reproducing the issue.
Thank you for taking time to look into this!
