Deepstream-6.0 : Depends: libgstreamer-plugins-base1.0-dev (>= 1.14.1) but it is not going to be installed
• Tesla t4
• DeepStream Version 6.0.1
• TensorRT Version 8.0.1
• Issue Type( new requirements, bugs)
sudo apt-get install ./deepstream-6.0_6.0.1-1_amd64.deb
Reading package lists… Done
Building dependency tree
Reading state information… Done
Note, selecting ‘deepstream-6.0’ instead of ‘./deepstream-6.0_6.0.1-1_amd64.deb’
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
deepstream-6.0 : Depends: libgstreamer-plugins-base1.0-dev (>= 1.14.1) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
Please refer to Quickstart Guide — DeepStream 6.0.1 Release documentation for installing DeepStream
