[DeepStream 6.0 GA] ERROR: <create_bboxfilter_bin:40>: Failed to create 'nvbboxfilter'
• Hardware Platform (Jetson AGX)
• DeepStream Version 6.0
• JetPack Version 4.6
• TensorRT Version 7.2.2
• Issue Type questions,
I extracted the source code of deepstream-360d-apps from nvcr.io/nvidia/deepstream_360d:5.0-20.08, and then compiled it on AGX to generate deepstream-360d-apps
Makefile in here
APP:= deepstream-360d-app
SRCS:= $(wildcard *.cpp)
SRCS+= $(wildcard *.c)
SRCS+= $(wildcard ../../apps-common/src/*.c)
NVDS_VERSION:=6.0
INCS:= $(wildcard *.h)
LIB_INSTALL_DIR?=/opt/nvidia/deepstream/deepstream-$(NVDS_VERSION)/lib
PKGS:= gstreamer-1.0 gstreamer-video-1.0 x11 json-glib-1.0
OBJS:= $(SRCS:.c=.o)
OBJS:= $(OBJS:.cpp=.o)
CFLAGS+= -I../../apps-common/includes -I../../../includes -DDS_VERSION_MINOR=0 -DDS_VERSION_MAJOR=6
LIBS:= -lm -L$(LIB_INSTALL_DIR) -lnvdsgst_meta -lnvds_utils -lnvdsgst_helper -lnvdsgst_smartrecord \
       -lgstrtspserver-1.0 -ldl -lnvds_meta -lnvds_msgbroker \
       -Wl,-rpath,$(LIB_INSTALL_DIR)
CFLAGS+= `pkg-config --cflags $(PKGS)`
LIBS+= `pkg-config --libs $(PKGS)`
all: $(APP)
%.o: %.c $(INCS) Makefile
	$(CC) -c -o $@ $(CFLAGS) $<
%.o: %.cpp $(INCS) Makefile
	$(CXX) -c -o $@ $(CFLAGS) $<
$(APP): $(OBJS) Makefile
	$(CXX) -o $(APP) $(OBJS) $(LIBS)
clean:
	rm -rf $(OBJS) $(APP)
Since the video file was not found, I modified the config file as follows
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=5
#gie-kitti-output-dir=streamscl
enable_bboxfilter=1
[tiled-display]
enable=1
# adjust the parameter 1 to 2
rows=2
columns=2
width=1280
height=720
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI 4=RTSP 5=CSI
type=1
camera-width=640
camera-height=480
camera-fps-n=30
camera-fps-d=1
camera-v4l2-dev-node=0
[source1]
enable=1
type=1
camera-width=640
camera-height=480
camera-fps-n=30
camera-fps-d=1
camera-v4l2-dev-node=1
[source2]
enable=1
type=1
camera-width=640
camera-height=480
camera-fps-n=30
camera-fps-d=1
camera-v4l2-dev-node=2
[source3]
enable=1
type=3
uri=file://../../streams/sample_1080p_h264.mp4
num-sources=1
#drop-frame-interval=2
gpu-id=0
# (0): memtype_device   - Memory type Device
# (1): memtype_pinned   - Memory type Host Pinned
# (2): memtype_unified  - Memory type Unified
cudadec-memtype=0
[sink0]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File
type=2
sync=1
source-id=0
gpu-id=0
nvbuf-memory-type=0
qos=0
[sink1]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File 4=UDPSink 5=nvoverlaysink 6=MsgConvBroker
type=6
msg-conv-config=dstest5_msgconv_sample_config.txt
#(0): PAYLOAD_DEEPSTREAM - Deepstream schema payload
#(1): PAYLOAD_DEEPSTREAM_MINIMAL - Deepstream schema payload minimal
#(256): PAYLOAD_RESERVED - Reserved type
#(257): PAYLOAD_CUSTOM   - Custom schema payload
msg-conv-payload-type=0
msg-broker-proto-lib=/opt/nvidia/deepstream/deepstream-6.0/lib/libnvds_kafka_proto.so
#Provide your msg-broker-conn-str here
msg-broker-conn-str=foo.bar.com;9092;dsapp1
topic=dsapp1
disable-msgconv=1
[sink2]
enable=0
#Type - 1=FakeSink 2=EglSink 3=File 4=RTSPStreaming
type=4
#1=h264 2=h265
codec=1
sync=0
bitrate=4000000
# set below properties in case of RTSPStreaming
rtsp-port=8554
udp-port=5400
[spot]
enable=1
# Threshold in seconds
result-threshold=10
component-id=1
calibration-file=./csv_files/nvspot_2M.csv
[aisle]
enable=1
component-id=2
calibration-file=./csv_files/nvaisle_2M.csv
[osd]
enable=1
gpu-id=0
border-width=1
text-size=15
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Serif
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=0
[dewarper]
enable=1
gpu-id=0
num-surfaces-per-frame=4
config-file=./config_dewarper.txt
[streammux]
gpu-id=0
##Boolean property to inform muxer that sources are live
live-source=0
batch-size=40
##time out in usec, to wait after the first buffer is available
##to push the batch even if the complete batch is not formed
batched-push-timeout=40000
## Set muxer output width and height
width=960
height=752
##Enable to maintain aspect ratio wrt source, and allow black borders, works
##along with width, height properties
enable-padding=0
nvbuf-memory-type=0
## If set to TRUE, system timestamp will be attached as ntp timestamp
## If set to FALSE, ntp timestamp from rtspsrc, if available, will be attached
attach-sys-ts-as-ntp=1
[tracker]
enable=1
tracker-width=640
tracker-height=384
ll-lib-file=/opt/nvidia/deepstream/deepstream-5.0/lib/libnvds_mot_iou.so
#ll-lib-file=/opt/nvidia/deepstream/deepstream-5.0/lib/libnvds_nvdcf.so
#ll-lib-file=/opt/nvidia/deepstream/deepstream-5.0/lib/libnvds_mot_klt.so
#ll-config-file required for DCF/IOU only
#ll-config-file=tracker_config.yml
ll-config-file=iou_config.txt
gpu-id=0
#enable-batch-process applicable to DCF only
#enable-batch-process=1
tracking-surface-type=2
#(1) => SPOT Surface, (2) => AISLE Surface
# config-file property is mandatory for any gie section.
# Other properties are optional and if set will override the properties set in
# the infer config file.
[primary-gie]
enable=1
gpu-id=0
#model-engine-file=../../models/Primary_Detector/resnet10.caffemodel_b30_int8.engine
#Required to display the PGIE labels, should be added even when using config-file
#property
bbox-border-color0=1;0;0;1
bbox-border-color1=0;1;1;1
bbox-border-color2=0;0;1;1
bbox-border-color3=0;1;0;1
interval=0
#Required by the app for SGIE, when used along with config-file property
gie-unique-id=1
nvbuf-memory-type=0
config-file=config_infer_primary.txt
batch-size=40
[tests]
file-loop=0
When I run the following command, I get an error like this
sudo ./deepstream-360d-app -c …/…/…/…/samples/configs/deepstream-360d-app/source10_gpu0.txt
ERROR :
(deepstream-360d-app:18421): GLib-GObject-CRITICAL **: 15:28:50.827: g_object_set: assertion 'G_IS_OBJECT (object)' failed
(deepstream-360d-app:18421): GLib-GObject-CRITICAL **: 15:28:50.829: g_object_set: assertion 'G_IS_OBJECT (object)' failed
(deepstream-360d-app:18421): GLib-GObject-CRITICAL **: 15:28:50.831: g_object_set: assertion 'G_IS_OBJECT (object)' failed
** ERROR: <create_bboxfilter_bin:40>: Failed to create 'nvbboxfilter'
** ERROR: <create_bboxfilter_bin:59>: create_bboxfilter_bin failed
creating bboxfilter bin failed
** ERROR: <create_pipeline:1048>: create_pipeline failed
** ERROR: <main:631>: Failed to create pipeline
Quitting
App run failed
Can you help me?
Thank you
Can you check with below guide and run other samples to verify your environment?
Quickstart Guide — DeepStream 6.0 Release documentation (nvidia.com)
I can run other config file .
