DeepStream 6.0 install error on NX
Description
DeepStream 6.0 install error on NX, could not compile librdkafka
Environment
TensorRT Version: 8.0.1.6
GPU Type: NVIDIA Tegra Xavier
Nvidia Driver Version:
CUDA Version: 10.2.300
CUDNN Version: 8.1.2.32
Operating System + Version: Ubuntu 18.04.5
Python Version (if applicable):
TensorFlow Version (if applicable):
PyTorch Version (if applicable):
Baremetal or Container (if container which image + tag):
Steps To Reproduce
I followed this link to install DeepStream on Xavier NX module, since the emmc attached to the product module has only 16GB space, SDK manager could not install DeepStream into it.
Errors occur while doing the librdkafka at SETPmake
$ cd librdkafka
$ git reset --hard 7101c2310341ab3f4675fc565f64f0967e135a6a
./configure
$ make
$ sudo make install
and the log is as follows:
crc32c.c: In function ‘crc32c_global_init’:
crc32c.c:349:9: error: unknown register name ‘%edx’ in ‘asm’
         __asm__("cpuid" \
crc32c.c:380:9: note: in expansion of macro ‘SSE42’
         SSE42(sse42);
crc32c.c:349:9: error: unknown register name ‘%ebx’ in ‘asm’
         __asm__("cpuid" \
         SSE42(sse42);
../mklove/Makefile.base:77: recipe for target 'crc32c.o' failed
make[1]: *** [crc32c.o] Error 1
make[1]: Leaving directory '/home/biao/Archive/librdkafka/src'
Makefile:20: recipe for target 'libs' failed
make: *** [libs] Error 2
Hi, This looks like a deepstream issue. We recommend you to raise it to the respective forum.
