Hello, rather new to this. Needed some help with upgrading from DeepStream 5 to 6
Re: background on the issue, our app needs to install the python bindings: pydso to compile the app we have created. This was automatically done in our docker container; post the installation of pydso. The installation was done using the following lines in a shell script:
The directory paths shown above work for deepstream 5, however it fails in deepstream 6. pyds.so and setup.py can’t be found. Our main issue is simply to get the correct directory paths for these files so that we can complete the compilation of the app.
Thanks so much for the suggestion. That problem no longer exists now, but I have a different issue now. When I run the app, I’m using some stock PyTorch models on it, which I put on the gpu device. However I get the following error
RuntimeError: Unexpected error from cudaGetDeviceCount(). Did you run some cuda functions before calling NumCudaDevices() that might have already set an error? Error 803: system has unsupported display driver / cuda driver combination
Is it because specific cuda drivers are being used, and there’s a mismatch between my PyTorch installation & cuda pre-installed in the Deepstream6.1.1 docker image?
Can you share the full log of executing your app? Does your deepstream program import modules from torch and torchvision? Not sure which part causes this error, you may run deepstream-test1 python example in your environment to check if the python environment for deepstream is OK.
Please also provide complete information as applicable to your setup.
• DeepStream Version
• TensorRT Version
• The pipeline being used
Hello, of course, the following is the error I receive.
reader = FUNCTION(ARG)
File "ROOT DIR BLOCKED FOR PRIVACY", line 55, in __init__
self.model = self.model.to(self.device)
File "/usr/local/lib/python3.8/dist-packages/lightning_fabric/utilities/device_dtype_mixin.py", line 54, in to
return super().to(*args, **kwargs)
File "/usr/local/lib/python3.8/dist-packages/torch/nn/modules/module.py", line 927, in to
return self._apply(convert)
File "/usr/local/lib/python3.8/dist-packages/torch/nn/modules/module.py", line 579, in _apply
module._apply(fn)
module._apply(fn)
module._apply(fn)
File "/usr/local/lib/python3.8/dist-packages/torch/nn/modules/module.py", line 602, in _apply
param_applied = fn(param)
File "/usr/local/lib/python3.8/dist-packages/torch/nn/modules/module.py", line 925, in convert
return t.to(device, dtype if t.is_floating_point() or t.is_complex() else None, non_blocking)
File "/usr/local/lib/python3.8/dist-packages/torch/cuda/__init__.py", line 217, in _lazy_init
torch._C._cuda_init()
My app does import from torch and torch vision both, in particular it fails when I put my model on the GPU device i.e. the following line:
where the device arg is “cuda”. The hardware of the device (not Jetson based), basically a laptop with a NVIDIA GPU:
CPU: Intel® Xeon(R) CPU
GPU: 1 x NVIDIA RTX A5000 GPU
Memory: 62.5 GiB
Deepstream 6 is installed in a docker container, and PyTorch + torch vision installed is for cuda 11.6:
