• Hardware Platform (Jetson / GPU) GPU GTX 1650 • DeepStream Version 6.1.1 • TensorRT Version8.4.1
**• CUDA version 11.7
**• NVIDIA GPU Driver Version (valid for GPU only)**515.65.01
I’m attempting to run the Deepstream 6.1.1 sample app Test2 in Python on my GPU laptop, however the video inference does not appear.
give below error
Error: gst-stream-error-quark: Internal data stream error. (1): gstnvinfer.cpp(2125): gst_nvinfer_submit_input_buffer (): /GstPipeline:pipeline0/GstNvInfer:secondary3-nvinference-engine:
streaming stopped, reason not-negotiated (-4) logs (19.3 KB)
Do you have a monitor connected to your PC? It seems the EGL cannot be initialized.
Besides, are you able to deepstream-app sample (or the corresponding C sample sources/apps/sample_apps/deepstream-test2) on your PC?
From your log, it shows there is problem with your display system.
Did you run it directly on your laptop or in a docker?
If in a docker, you can use the command below to set your env:
Thank you for your support, Yuweiw.
My issue was resolved.
using the guidelines listed below
sudo prime-select nvidia
sudo reboot
————- If still a problem, try ———-
install nvidia-docker2
