DeepStream 6.1 is now available for download.
This is the first release of DeepStream that supports Orin (JetPack 5.0.1 DP).
For download links and details on the release please visit:
https://developer.nvidia.com/deepstream-getting-started
Happy DeepStreaming!
HI, I have a question:
Is it still compatible with Ubuntu 18.04?
No. It is based on ubuntu 20.04
Will 6.1 support the Nano? The Quickstart guide does not list the Nano as a supported Jetson device:
https://docs.nvidia.com/metropolis/deepstream/dev-guide/text/DS_Quickstart.html
Hey @Fiona.Chen @yingliu
I followed the getting started guide to install deepstream-6.1 but the sample apps doesn’t work with my RTX 3070.
Please check below when I try to run source30 with resnet model
user@user-RTX3070:/opt/nvidia/deepstream/deepstream/samples/configs/deepstream-app$ sudo deepstream-app -c source30_1080p_dec_infer-resnet_tiled_display_int8.txt
0:00:04.236698627 3051 0x564eed661c30 INFO nvinfer gstnvinfer.cpp:646:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1900> [UID = 1]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-6.1/samples/configs/deepstream-app/…/…/models/Primary_Detector/resnet10.caffemodel_b30_gpu0_int8.engine
INFO: …/nvdsinfer/nvdsinfer_model_builder.cpp:610 [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input_1 3x368x640
1 OUTPUT kFLOAT conv2d_bbox 16x23x40
2 OUTPUT kFLOAT conv2d_cov/Sigmoid 4x23x40
0:00:04.248962261 3051 0x564eed661c30 INFO nvinfer gstnvinfer.cpp:646:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2003> [UID = 1]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-6.1/samples/configs/deepstream-app/…/…/models/Primary_Detector/resnet10.caffemodel_b30_gpu0_int8.engine
0:00:04.250771153 3051 0x564eed661c30 INFO nvinfer gstnvinfer_impl.cpp:328:notifyLoadModelStatus:<primary_gie> [UID 1]: Load new model:/opt/nvidia/deepstream/deepstream-6.1/samples/configs/deepstream-app/config_infer_primary.txt sucessfully
Runtime commands:
h: Print this help
q: Quit
p: Pause
r: Resume
NOTE: To expand a source in the 2D tiled display and view object details, left-click on the source.
To go back to the tiled display, right-click anywhere on the window.
** INFO: <bus_callback:194>: Pipeline ready
cuGraphicsGLRegisterBuffer failed with error(219) gst_eglglessink_cuda_init texture = 1
0:00:04.921388978 3051 0x564eebbc96a0 WARN nvinfer gstnvinfer.cpp:2299:gst_nvinfer_output_loop:<primary_gie> error: Internal data stream error.
0:00:04.921421374 3051 0x564eebbc96a0 WARN nvinfer gstnvinfer.cpp:2299:gst_nvinfer_output_loop:<primary_gie> error: streaming stopped, reason not-negotiated (-4)
ERROR from primary_gie: Internal data stream error.
Debug info: gstnvinfer.cpp(2299): gst_nvinfer_output_loop (): /GstPipeline:pipeline/GstBin:primary_gie_bin/GstNvInfer:primary_gie:
Quitting
ERROR from sink_bin_queue: Internal data stream error.
Debug info: gstqueue.c(988): gst_queue_handle_sink_event (): /GstPipeline:pipeline/GstBin:processing_bin_0/GstBin:sink_bin/GstQueue:sink_bin_queue:
ERROR from qtdemux13: Internal data stream error.
Debug info: qtdemux.c(6605): gst_qtdemux_loop (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin3/GstURIDecodeBin:src_elem/GstDecodeBin:decodebin3/GstQTDemux:qtdemux13:
ERROR from qtdemux19: Internal data stream error.
Debug info: qtdemux.c(6605): gst_qtdemux_loop (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin19/GstURIDecodeBin:src_elem/GstDecodeBin:decodebin19/GstQTDemux:qtdemux19:
ERROR from multiqueue18: Internal data stream error.
Debug info: gstmultiqueue.c(2357): gst_multi_queue_sink_event (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin19/GstURIDecodeBin:src_elem/GstDecodeBin:decodebin19/GstMultiQueue:multiqueue18:
ERROR from qtdemux15: Internal data stream error.
Debug info: qtdemux.c(6605): gst_qtdemux_loop (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin14/GstURIDecodeBin:src_elem/GstDecodeBin:decodebin14/GstQTDemux:qtdemux15:
ERROR from multiqueue13: Internal data stream error.
Debug info: gstmultiqueue.c(2357): gst_multi_queue_sink_event (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin14/GstURIDecodeBin:src_elem/GstDecodeBin:decodebin14/GstMultiQueue:multiqueue13:
ERROR from qtdemux27: Internal data stream error.
Debug info: qtdemux.c(6605): gst_qtdemux_loop (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin28/GstURIDecodeBin:src_elem/GstDecodeBin:decodebin28/GstQTDemux:qtdemux27:
ERROR from multiqueue27: Internal data stream error.
Debug info: gstmultiqueue.c(2357): gst_multi_queue_sink_event (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin28/GstURIDecodeBin:src_elem/GstDecodeBin:decodebin28/GstMultiQueue:multiqueue27:
App run failed
I have nvidia drivers which are mentioned on the site along with cuda and tensorrt…
Any clarification on if DS6.1 will support the nano?
@harryhsl8c Nano is not supported, please refer to Quickstart Guide — DeepStream 6.1.1 Release documentation for detailed support list.
For new question please submit topic in forum, thanks.
