I run Deepstream 6.3 be nvbufsurftransform:cuInit failed:999 on RTX 4090, is there the conflict between GPU vs Deepstream version or other something wrong. Can you help me? Thanks a lot.
• DeepStream Version
• TensorRT Version
• The pipeline being used
From cuInit failed:999
unable to determine the problem.
Are you using Docker or some other method to run DeepStream?
This is the GPU driver and DeepStream compatibility table
https://docs.nvidia.com/metropolis/deepstream/dev-guide/text/DS_Installation.html#id9
