Deepstream 6.3 : Too long to start with sample-app (resent_tracker)
In you last comment, is is the first time to run app? if the engine was generated, from the second run, the app will load the existing engine directly instead of creating a new engine.
This isn’t the first time.
I’ve already run it multiple times.
The ‘source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt’ file correctly mentions the primary engine.
Noticing the screenshot was only part of whole log, could you share the whole log? you can attach txt file. and please check why the app can’t save the engine to that path. it should be related to permission.
Here is my whole log.
source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt (6.0 KB)
I suppose there was a existing resnet10.caffemodel_b2_gpu0_int8.engine generated by root permission. the app failed to replace it . you can delete it first, then the app will create a new engine.
