Confirmed. There is an incompatibility when using a Ubuntu Docker image with a version lower than that of the physical host.
Related topics
| DeepStream 6.4 - Gst-nvstreammux Plugin Hangs Indefinitely | 15 | 1052 | January 12, 2024 | |
| Deepstream6.4 docker run test1.py issue | 5 | 350 | April 23, 2024 | |
| Deepstream setup issues | 6 | 2799 | February 23, 2022 | |
| Deepstream docker orin - Need help getting a working system up | 7 | 201 | July 12, 2024 | |
| FAIL to run deepstream 6-0 on T4 server | 31 | 1902 | January 4, 2022 | |
| Deepstream 6.4 running issue | 4 | 503 | January 18, 2024 | |
| Deepstream6.4 in Ubuntu24 Pipeline Not running | 19 | 381 | July 23, 2024 | |
| Requested 'gstreamer-1.0 >= 1.16.2' but version of GStreamer is 1.14.5 | 9 | 568 | August 12, 2022 | |
| Could not receive any UDP packets for 5.0000 seconds, maybe your firewall is blocking it. Retrying using a tcp connection | 32 | 971 | September 4, 2023 | |
| Deepstream-app: error while loading shared libraries: libnvinfer.so.6: cannot open shared object file + ubuntu 18.04 | 27 | 8532 | October 12, 2021 |
