tiyeesa
December 2, 2021, 2:15am
24
Hi, @adventuredaisy
I applied the it by using this:
/opt/nvidia/deepstream/deepstream-6.0/sources/objectDetector_Yolo$ sudo patch -p1 < ~/DS6.0_objectDetector_Yolo_perf_regression.patch
I checked that the code changed after running the patch file.
but I couldn’t get any difference even after applying it.
I still getting about 11 fps…
mchi
December 2, 2021, 2:23am
25
adventuredaisy:
warning: nvdsinfer_custom_impl_Yolo/nvdsinfer_yolo_engine.cpp has type 100755, expected 100644
error: cannot apply binary patch to ‘nvdsinfer_custom_impl_Yolo/nvdsinfer_yolo_engine.o’ without full index line
error: nvdsinfer_custom_impl_Yolo/nvdsinfer_yolo_engine.o: patch does not apply
warning: nvdsinfer_custom_impl_Yolo/yolo.cpp has type 100755, expected 100644
warning: nvdsinfer_custom_impl_Yolo/yolo.h has type 100755, expected 100644
error: cannot apply binary patch to ‘nvdsinfer_custom_impl_Yolo/yolo.o’ without full index line
error: nvdsinfer_custom_impl_Yolo/yolo.o: patch does not apply
Sorry! The patch includes some .o files, and generated under docker, so there are patch apply error to .o files & warining about file permission change. You can ignore these error and warning.
I went through the log, seems the patch was applied successfully .
mchi
December 2, 2021, 2:26am
26
You need to rebuild the libnvdsinfer_custom_impl_Yolo.so with
$ export CUDA_VER= …
$ make -C nvdsinfer_custom_impl_Yolo
mchi
December 2, 2021, 2:37am
27
Sorry all!
I updated the patch and steps to apply the patch in post#22 (Deepstream 6 YOLO performance issue - #22 by mchi ) above.
tiyeesa
December 2, 2021, 3:22am
28
mchi:
m
My bad! It shows about 55 fps after rebuild.
Beautiful
55 fps also
My faith in you’re skills to surmount this problem never wavered
OK maybe a little bit
But you didn’t let us down.
Thank you
mfoglio
December 13, 2021, 8:07pm
31
Could I have this issue when using the container nvcr.io/nvidia/deepstream:6.0-triton
system
Closed
December 27, 2021, 8:07pm
32
