• Hardware Platform (Jetson / GPU): GPU Nvidia A40 • DeepStream Version: 7.0 • JetPack Version (valid for Jetson only) • TensorRT Version • NVIDIA GPU Driver Version (valid for GPU only): 535 • Issue Type( questions, new requirements, bugs): Bugs • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) • Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
Due to the timestamps issue I have recently migrated from DS:6.2 to DS:7.0. But now its getting stops by throwing below error. Any help will be highly appreciated.
deepstream-1 | ERROR from splitmuxsink4: Timestamping error on input streams
deepstream-1 | Debug info: ../gst/multifile/gstsplitmuxsink.c(2594): handle_gathered_gop (): /GstPipeline:pipeline/GstBin:processing_bin_4/GstBin:sink_bin/GstBin:sink_sub_bin15/GstHlsSink2:hls_mux/GstSplitMuxSink:splitmuxsink4:
deepstream-1 | Queued GOP time is negative -0:00:00.621997728
deepstream-1 | Quitting
deepstream-1 | ERROR from split_mux: Timestamping error on input streams
deepstream-1 | Debug info: ../gst/multifile/gstsplitmuxsink.c(2594): handle_gathered_gop (): /GstPipeline:pipeline/GstBin:processing_bin_4/GstBin:sink_bin/GstBin:sink_sub_bin16/GstSplitMuxSink:split_mux:
deepstream-1 | [NvMultiObjectTracker] De-initialized
Please provide complete information as applicable to your setup. • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing)
We are running deepstream_test5 application. Total 16 live cameras we are running in that application inside the docker container. config_infer_primary_yolov8.txt (940 Bytes)
