Deepstream 7.0 FPS Less Utilization Error
**• Hardware Platform (GPU) T4
**• DeepStream Version 7.0
**• NVIDIA GPU Driver Version
Driver Version: 535.104.05 CUDA Version: 12.2
**• Issue Type:
when i run my source file in deepstream the fps is low but not utilizing gpu and cpu fully
CPU state during running
Screenshot from 2024-05-24 16-37-48
gpu state during run:
Config files:
deepstream_app_source1_peoplenet.txt (4.9 KB)
config_infer_primary_facedetectir.txt (2.3 KB)
config_infer_age_classifier.txt (3.5 KB)
so far planning to run primary and age as secondary others are not running (keep it disable)
Can you upload the “/home/glueck/Documents/sunway/test3.mp4” file too?
Please use “nvidia-smi dmon” to get the whole GPU loading log.
Sorry, the video is confidential, it belongs to our client. But we can discuss sharing it privately if needed.
gpu loading log:
So please check the original FPS of the “/home/glueck/Documents/sunway/test3.mp4” file. You choose the display sink with synchronization in your configuration file, the GPU loading and CPU loading are all in normal state, the whole pipeline should run according to the FPS of the video itself.
I’ve checked the frame rate, its 15, the pipeline is running properly, I’ve tested with a 30 fps video and its doing fine. Thanks for the help.
Is there still any issue to be discussed?
No its clear now
Glad to hear that!
