DeepStream 7.1 on Jetson Orin NX: Track Fragmentation and Re-ID Issues with NvDeepSORT and NvDCF
Dear NVIDIA Support Team,
We are investigating multi-object tracking performance in NVIDIA DeepStream 7.1 on the Jetson Orin NX platform. We are experiencing track fragmentation, identity switches, and occasional instability in object localization, and would appreciate your recommendations on tracker selection, configuration, and debugging.
1. Problem Description
Our application performs multi-object tracking for pedestrians and vehicles using NVIDIA PeopleNet and TrafficCamNet, respectively. We have evaluated both NvDeepSORT and NvDCF and observed the following issues during visual inspection of the tracker outputs:
  • Track fragmentation: Existing tracks terminate prematurely and new track IDs are assigned to objects that appear to be the same physical entities.
  • Identity switches: Track IDs occasionally switch between objects, particularly when multiple objects are close together, cross paths, or become partially occluded.
  • Localization instability: Bounding boxes occasionally exhibit jitter or inconsistent localization over consecutive frames.
  • Missed-detection recovery: Tracks may not consistently retain their identities when objects are temporarily missed by the detector or partially occluded.
These observations are preliminary and are based on visual inspection. We have not yet completed a quantitative evaluation using standard multi-object tracking metrics.
Our objective is to improve identity consistency, reduce track fragmentation and identity switches, and maintain stable bounding boxes without introducing excessive false-positive tracks or tracking latency.
2. Environment
  • Hardware: NVIDIA Jetson Orin NX
  • Operating system: Ubuntu 22.04.5 LTS
  • JetPack: 6.2.1
  • L4T: 36.4.4
  • CUDA: 12.6
  • DeepStream: 7.1
  • Detection models: NVIDIA PeopleNet and TrafficCamNet
  • Re-identification model: NVIDIA-provided Re-ID model
  • Object classes: Pedestrians and vehicles
  • Trackers evaluated: NvDeepSORT and NvDCF
3. Experiments and Configuration Areas
We have experimented with NvDeepSORT and NvDCF to assess tracking performance and identify potential improvements through tracker configuration.
For NvDCF, we are particularly interested in the effects of the following Kalman filter noise parameters:
  • processNoiseVar4Loc
  • processNoiseVar4Size
  • processNoiseVar4Vel
  • measurementNoiseVar4Detector
  • measurementNoiseVar4Tracker
We would appreciate guidance on whether tuning these parameters is likely to improve localization stability and tracking continuity, and how to distinguish state-estimation problems from data-association or detector-related problems.
We are also interested in the impact of tracker data-association thresholds, visual tracking parameters, track confirmation and termination criteria, and recovery behavior following temporary detection failures.
4. Questions for NVIDIA Support
1. Tracker selection
For pedestrian and vehicle tracking with PeopleNet and TrafficCamNet, respectively, would you recommend NvDeepSORT or NvDCF when identity consistency and reduced track fragmentation are the primary objectives? Are there circumstances in which a hybrid or class-specific configuration would be preferable?
2. Track lifecycle management
Which configuration parameters should we prioritize for track confirmation, termination, shadow tracking, and recovery following temporary occlusion or missed detections? How should we balance track retention against the risk of maintaining stale or incorrect tracks?
3. NvDeepSORT and Re-ID compatibility
Given that we use an NVIDIA-provided Re-ID model, are there recommended NvDeepSORT configuration settings, input preprocessing requirements, feature compatibility considerations, or appearance-association thresholds that could improve identity consistency? Are there model-specific constraints we should verify?
4. NvDCF configuration and Kalman filter tuning
Which NvDCF parameters should we investigate first for the following concerns?
  • Data association and matching thresholds
  • Visual tracker robustness and bounding-box localization
  • State estimation and motion prediction
  • Detector and tracker measurement noise
  • Track initialization, shadow tracking, and termination
In particular, we would appreciate guidance on the expected effects of processNoiseVar4Loc, processNoiseVar4Size, processNoiseVar4Vel, measurementNoiseVar4Detector, and measurementNoiseVar4Tracker, including any recommended tuning methodology or starting values appropriate for our use case.
5. Crowded scenes and temporary occlusion
Are there recommended NvDeepSORT or NvDCF configurations for scenes containing multiple pedestrians and vehicles, particularly when objects cross paths, overlap, become partially occluded, or are temporarily missed by the detector?
6. DeepStream 7.1-specific considerations
Are there known limitations, relevant bug fixes, or configuration considerations in DeepStream 7.1 on Jetson Orin NX that could contribute to identity switches, track fragmentation, or localization instability? Are there any recommended patches or later maintenance releases we should evaluate?
7. Reference configuration
Could you provide a reference configuration or parameter-tuning recommendations for NvDeepSORT and NvDCF that are appropriate for our software environment, detector models, and multi-object tracking requirements?
5. Proposed Debugging and Evaluation
We would also appreciate recommendations for isolating the source of the observed issues.
We can provide our main DeepStream pipeline configuration, NvDeepSORT and NvDCF configuration files, PeopleNet and TrafficCamNet inference configuration files, representative video clips, application logs, and tracker outputs.
In particular, we would welcome guidance on:
  • Verifying detector bounding-box quality and confidence scores before tracking.
  • Inspecting tracker IDs, object metadata, association behavior, and track lifecycle transitions.
  • Evaluating the influence of detector inference intervals, frame rate, and temporary missed detections.
  • Measuring identity switches, track fragmentation, localization accuracy, and tracking continuity using standard multi-object tracking metrics.
  • Identifying whether the observed issues originate primarily from detection quality, data association, Re-ID, state estimation, or track lifecycle management.
Our goal is to establish a reproducible evaluation procedure and identify the configuration changes most likely to improve tracking quality on Jetson Orin NX.
Thank you for your time and technical assistance. We look forward to your recommendations.
tracking-diagnostics.zip (21.7 MB)
Hello @adithyaskumar235!
Based on the title and content of your topic, it looks like it may receive better visibility and feedback in a different category. We took the liberty of moving it for you.
If this was an incorrect assessment, please send me a direct message.
Disclaimer: this moderation suggestion and message were generated with AI assistance.
Can you have a try with: /opt/nvidia/deepstream/deepstream-9.2/samples/configs/deepstream-app/config_tracker_NvDCF_accuracy.yml on DeepStream 9.2 on JetPack 7.2.1?
Thank you for your recommendation.
Could you kindly clarify how the NvDCF accuracy preset and the upgrade to DeepStream 9.2 are expected to address our specific issues with track fragmentation, identity switches, and localization instability?
This would help us understand the expected benefits and plan our evaluation accordingly.
Thank you for your time and guidance.
Object ID switch is one common issue of nvtracker. We are improve nvtracker accuracy in every DeepStream release. So please upgrade to latest DeepStream 9.2 to have a test. config_tracker_NvDCF_accuracy.yml is tuned for accuracy, please use this config file to have a try.
Which would you recommend as tracker for pedestrians/workers NvDeepSORT or NvDCF ?
Please have a try with NvDCF(config_tracker_NvDCF_accuracy.yml) on the latest DeepStream release 9.2.
