Hardware Platform: NVIDIA GPU (GeForce RTX 5080, running on PC with WSL2 + Docker)
Environment:
DeepStream Version: 8.0.0
JetPack Version: N/A (PC/WSL2 environment)
TensorRT Version: 10.9
CUDA Driver Version: 577.00
CUDA Runtime Version: 12.8
cuDNN Version: 9.8
libNVWarp360 Version: 2.0.1d3
Installation: DeepStream 8.0 Docker on WSL2
Issue Type: Bug
Description of the Issue:
I am running DeepStream 8.0 in Docker on WSL2 and trying to save cropped object images using nvds_obj_enc_process.
The encoder context is created successfully at startup in create_pipeline this function in deepstream_app.c:
appCtx->obj_ctx_handle = nvds_obj_enc_create_context(0);
if (!appCtx->obj_ctx_handle) {
g_print("ERROR: Unable to create obj encoder context for GPU %d\n", gpu_id);
return -1;
g_print("Successfully created obj encoder context\n");
Output confirms context creation:
But later, when calling nvds_obj_enc_process, the function fails:
DEBUG: Using surface index: 1
ERROR: nvds_obj_enc_process failed with return code: 1
- Object ID: 3
- Source ID: 1
Steps to Reproduce:
Run DeepStream 8.0 Docker inside WSL2 with GPU passthrough.
Add custom code to save cropped images with
nvds_obj_enc_process. -
Run the custom app:
./deepstream-app-custom -c config/deepstream_app_config.txt
Observed Behavior:
nvds_obj_enc_processfails withreturn code: 1even thoughframe_meta,obj_meta, andip_surfare valid. -
Application crashes with segmentation fault.
Expected Behavior:
The cropped object image should be saved successfully.
No segmentation fault should occur when encoder context has already been created.
Additional Notes:
I verified that
frame_meta,obj_meta, andip_surfare valid when passed tonvds_obj_enc_process. -
Encoder context is created and confirmed, but still fails during image saving.
This issue only happens in Docker on WSL2 — it may be related to GPU driver passthrough or encoding libraries in WSL.
this is the code:static void save_alert_image(AppCtx *appCtx, long int count, NvBufSurface *ip_surf, NvDsFrameMeta *frame_meta, NvDsObjectMeta *obj_meta, bool calc_enc) { std::string temp_osd_string = "/opt/nvidia/deepstream/deepstream-8.0/images/"; const char* osd_string = temp_osd_string.c_str(); // Initialize frame data structure NvDsObjEncUsrArgs frameData; memset(&frameData, 0, sizeof(NvDsObjEncUsrArgs)); frameData.isFrame = 0; // 0 for object crop frameData.saveImg = true; frameData.attachUsrMeta = false; frameData.scaleImg = FALSE; frameData.scaledWidth = 0; frameData.scaledHeight = 0; frameData.quality = 80; if (calc_enc) { frameData.calcEncodeTime = 1; } snprintf(frameData.fileNameImg, sizeof(frameData.fileNameImg), "%s%ld.jpg", osd_string, count); guint surface_index = frame_meta->batch_id; if (surface_index >= ip_surf->numFilled) { g_print("Error: Invalid surface index %d (numFilled: %d)\n", surface_index, ip_surf->numFilled); return; } g_print("DEBUG: Using surface index: %d\n", surface_index); // Call encoder NvDsObjEncCtxHandle ctx = appCtx->obj_ctx_handle; gint ret = nvds_obj_enc_process(ctx, &frameData, ip_surf, obj_meta, frame_meta); if (ret != 0) { g_print("ERROR: nvds_obj_enc_process failed with return code: %d\n", ret); g_print(" - This usually means encoder context is not properly initialized\n"); g_print(" - Object ID: %ld\n", obj_meta->object_id); g_print(" - Source ID: %d\n", frame_meta->source_id); g_print(" - Check encoder initialization in your main setup code\n"); // DO NOT call finish after failure - this causes the segfault return; } g_print("DEBUG: nvds_obj_enc_process succeeded\n"); // Only call finish if process succeeded nvds_obj_enc_finish(ctx); g_print("SUCCESS: Alert image saved at %s%ld.jpg\n", osd_string, count); std::cout << "image_saved---------------------------" << std::endl; } extern "C" void parse_nvdsanalytics_meta_data_deepstream(GstBuffer *buf,AppCtx *appCtx,NvDsBatchMeta *batch_meta) { const gchar *calc_enc_str = g_getenv("CALCULATE_ENCODE_TIME"); gboolean calc_enc = !g_strcmp0(calc_enc_str, "yes"); GstMapInfo inmap = GST_MAP_INFO_INIT; if (!gst_buffer_map(buf, &inmap, GST_MAP_READ)) { GST_ERROR("input buffer mapinfo failed"); } NvBufSurface* ip_surf = (NvBufSurface *)inmap.data; if (appCtx->obj_ctx_handle == NULL) { g_print("Error: obj_ctx_handle is NULL. Did you initialize it?\n"); gst_buffer_unmap(buf, &inmap); return; } NvDsObjectMeta *obj_meta = NULL; NvDsMetaList * l_frame = NULL; NvDsMetaList * l_obj = NULL; NvDsMetaList *l_user = NULL; // auto current_time = std::chrono::steady_clock::now(); // auto time_elapsed = std::chrono::duration_cast<std::chrono::seconds>(current_time-last_sent_time); //NvDsBatchMeta *batch_meta = gst_buffer_get_nvds_batch_meta (buf); for (l_frame = batch_meta->frame_meta_list; l_frame != NULL; l_frame = l_frame->next) { NvDsFrameMeta *frame_meta = (NvDsFrameMeta *) (l_frame->data); int camera_id = frame_meta->source_id; char fileObjNameString[256]; int num_rect = 0; for (NvDsMetaList *l_obj = frame_meta->obj_meta_list;l_obj!=NULL;l_obj=l_obj->next){ NvDsObjectMeta *obj_meta = (NvDsObjectMeta *)(l_obj->data); int gie_unique_id = obj_meta->unique_component_id; if (gie_unique_id==2){ std::cout << "SECONDARY Model - " << "Class ID: " << obj_meta->class_id << ", Tracking ID: " << obj_meta->object_id << ", Confidence: " << obj_meta->confidence << ", Parent ID: " << obj_meta->parent->object_id // Link to primary detection << std::endl; std::string unique_id = std::to_string(obj_meta->parent->object_id)+"_"+std::to_string(obj_meta->class_id); std::cout << "Unique Secondary ID: " << unique_id << std::endl; save_alert_image(appCtx,obj_meta->parent->object_id,ip_surf,frame_meta,obj_meta->parent,calc_enc); } } } gst_buffer_unmap(buf, &inmap); }
