Hey all,
DeepStream 9.2 is live. Here’s what’s worth your attention:
[1] More of DeepStream is open source. The monorepo at github.com/NVIDIA/DeepStream now includes 12 GStreamer elements and 30+ libraries as source. These include the nvv4l2 codecs, nvunixfdsink/nvunixfdsrc and the Re-ID vision and text embedding plugins.
SDK packages (deb/tarball, including a new SBSA tarball) and the Python wheel are in the GitHub release assets.
Containers are on GHCR: Package deepstream · GitHub, 9.2-samples-multiarch and 9.2-triton-sbsa-dgx-spark.
SDKM / APT availability: coming 10/23.
[2] Build smarter VLM and active-learning pipelines.
Intelligent frame selection: send only the most relevant frames to vision-language models.
Active learning pipeline: curated frames go to Kafka, with runtime model switching,
[3] PyServiceMaker keeps growing. It now has 3D tracker metadata, child-proxy property access, and reusable Python probes for metadata insertion, FPS measurement and KITTI output. Check Quick Start Guide if you’re migrating.
[4] More agentic skills. The bundled skills now cover compute-stack setup, vision-model onboarding, pipeline configuration and WSL setup.
[5] Platforms: NVIDIA GB300 support and JetPack 7.2.1.
Full list of supported platforms: x86 (dGPU, including GB300), ARM SBSA (DGX Spark, DGX Station), and Jetson via JetPack 7.2.1 (Thor and Orin).
Also in this release: a per-stream start-time log for checking multi-stream start alignment.
Want to learn more? See the Release Notes, FAQ and documentation.
Try it out and tell us what you build. Questions and feedback are welcome in the thread.
As always, happy DeepStreaming!
