I am using the deepstream for yoloV8 model with redis cache to get the predicted output for each frame, Using Deepstream docker image in that I am using deepstream_test5 app
Device info -
**• Hardware Platform (Jetson / GPU)** - Jetson Nano Dev Kit 4GB
**• DeepStream Version** - 6.0.1
**• JetPack Version (valid for Jetson only)** - 4.6.1
**• TensorRT Version** - 8.2.1.8
**• CUDA Version** - 10.2.300
**• cuDNN Version** - 8.2.1.32
configs -
[sink0]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File 4=UDPSink 5=nvoverlaysink 6=MsgConvBroker
type=6
msg-conv-config=dstest5_msgconv_sample_config.txt
#(0): PAYLOAD_DEEPSTREAM - Deepstream schema payload
#(1): PAYLOAD_DEEPSTREAM_MINIMAL - Deepstream schema payload minimal
#(256): PAYLOAD_RESERVED - Reserved type
#(257): PAYLOAD_CUSTOM - Custom schema payload
msg-conv-payload-type=1
msg-broker-proto-lib=/opt/nvidia/deepstream/deepstream-6.0/lib/libnvds_redis_proto.so
#Provide your msg-broker-conn-str here
msg-broker-conn-str=0.0.0.0;6379;deepstream_topic
topic=deepstream_topic
#Optional:
msg-broker-config=./configs/cfg_redis.txt
#msg-broker-config=../../deepstream-test4/cfg_kafka.txt
msg-conv-frame-interval=1
message-converter and message-consumer0 is not enabled, as the sink_type=6 includes the message conv. in default.
After few output data modification from redis cache, I got the output like this
42 Camera1 2025-04-11T11:07:31.523Z ['1|772.632|246.927|1061.42|1031.4|person']
Now, I need two extra values to send in the redis cache -
1. the confidence score for each object
2. the input frame for each frame_id
So, I gothorugh some documentation and in this directory /opt/nvidia/deepstream/deepstream-6.0/sources/libs/nvmsgconv/deepstream_schema/, the file name eventmsg_payload.cpp is handling the output parameters for each predicted objects
In line no, 671, a function is defined gchar* generate_event_message_minimal (void *privData, NvDsEvent *events, guint size)
I modified the function to get the confidence score for each object, for that I modified this line
ss << meta->trackingId << "|" << meta->bbox.left << "|" << meta->bbox.top << "|" << meta->bbox.left + meta->bbox.width << "|" << meta->bbox.top + meta->bbox.height << "|" << object_enum_to_str (meta->objType, meta->objectId);
to
ss << meta->trackingId << "|" << meta->bbox.left << "|" << meta->bbox.top << "|" << meta->bbox.left + meta->bbox.width << "|" << meta->bbox.top + meta->bbox.height << "|" << object_enum_to_str (meta->objType, meta->objectId) << "||" << meta->confidence;
then from redis cache, I got the confidence score for each object, but with value as ‘0’ for all detected object
I tried few modification, in other files also without knowing the C++, and none of the modification is succeeded to get the proper value of confidence.
I have checked the type of data the confidence is holdingtypeid(meta->confidence).name() and it returns d which is the double
I checked this value meta->objType by adding this parameter to send in redis cache, and i got the ‘258’ value for this parameter, what this means
and also for meta->extMsg, meta->extMsgSize both are having the value 0
How to get the confidence value and the input image from deepstream , could you please help me on this, thanks
