Deepstream app can perform detection but encountered this problem about OpenCV assertion, when using tracker
  rtx 2080ti
• DeepStream Version
  nvcr.io/nvidia/deepstream:5.0.1-20.09-triton
• TensorRT Version
 440.44
•Issue Type( questions, new requirements, bugs)
Following instruction https://github.com/DanaHan/Yolov5-in-Deepstream-5.0 to use yolov5 network to perform detection but encountered this problem. Not sure why it didn’t work. Thanks for your help!
config file
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=5
#gie-kitti-output-dir=streamscl
[tiled-display]
enable=1
rows=1
columns=1
width=1280
height=720
gpu-id=0
#(0): nvbuf-mem-default - Default memory allocated, specific to particular platform
#(1): nvbuf-mem-cuda-pinned - Allocate Pinned/Host cuda memory, applicable for Tesla
#(2): nvbuf-mem-cuda-device - Allocate Device cuda memory, applicable for Tesla
#(3): nvbuf-mem-cuda-unified - Allocate Unified cuda memory, applicable for Tesla
#(4): nvbuf-mem-surface-array - Allocate Surface Array memory, applicable for Jetson
nvbuf-memory-type=0
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI
type=3
uri=file:/opt/nvidia/deepstream/deepstream-5.0/samples/streams/sample_1080p_h264.mp4
#uri=file:/home/nvidia/Documents/5-Materials/Videos/0825.avi
num-sources=1
gpu-id=0
# (0): memtype_device   - Memory type Device
# (1): memtype_pinned   - Memory type Host Pinned
# (2): memtype_unified  - Memory type Unified
cudadec-memtype=0
[sink0]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File
type=4
sync=0
source-id=0
gpu-id=0
nvbuf-memory-type=0
#1=mp4 2=mkv
container=1
#1=h264 2=h265
codec=1
output-file=yolov4.mp4
bitrate=3000000
rtsp-port=8551
udp-port=5551
[osd]
enable=1
gpu-id=0
border-width=1
text-size=12
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Serif
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=0
[streammux]
gpu-id=0
##Boolean property to inform muxer that sources are live
live-source=0
batch-size=1
##time out in usec, to wait after the first buffer is available
##to push the batch even if the complete batch is not formed
batched-push-timeout=10
## Set muxer output width and height
width=1280
height=720
##Enable to maintain aspect ratio wrt source, and allow black borders, works
##along with width, height properties
enable-padding=0
nvbuf-memory-type=0
# config-file property is mandatory for any gie section.
# Other properties are optional and if set will override the properties set in
# the infer config file.
[primary-gie]
enable=1
gpu-id=0
model-engine-file=yolov5s.engine
labelfile-path=labels.txt
#batch-size=1
bbox-border-color0=1;0;0;1
bbox-border-color1=0;1;1;1
bbox-border-color2=0;0;1;1
bbox-border-color3=0;1;0;1
interval=0
gie-unique-id=1
nvbuf-memory-type=0
config-file=config_infer_primary_yoloV5.txt
[tracker]
enable=1
tracker-width=512
tracker-height=320
ll-lib-file=/opt/nvidia/deepstream/deepstream-5.0/lib/libnvds_mot_klt.so
[tests]
file-loop=1
log
*** DeepStream: Launched RTSP Streaming at rtsp://localhost:8551/ds-test ***
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream-5.0/lib/libnvds_mot_klt.so
gstnvtracker: Optional NvMOT_RemoveStreams not implemented
gstnvtracker: Batch processing is OFF
WARNING: ../nvdsinfer/nvdsinfer_func_utils.cpp:34 [TRT]: Current optimization profile is: 0. Please ensure there are no enqueued operations pending in this context prior to switching profiles
0:00:04.337667991 20187 0x5558c67c32f0 INFO                 nvinfer gstnvinfer.cpp:602:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1577> [UID = 1]: deserialized trt engine from :/deepstream/Yolov5-in-Deepstream-5.0/Deepstream_5.0/yolov5s.engine
INFO: ../nvdsinfer/nvdsinfer_model_builder.cpp:685 [Implicit Engine Info]: layers num: 2
0   INPUT  kFLOAT data            3x640x640
1   OUTPUT kFLOAT prob            6001x1x1
0:00:04.337759067 20187 0x5558c67c32f0 INFO                 nvinfer gstnvinfer.cpp:602:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1681> [UID = 1]: Use deserialized engine model: /deepstream/Yolov5-in-Deepstream-5.0/Deepstream_5.0/yolov5s.engine
0:00:04.338915118 20187 0x5558c67c32f0 INFO                 nvinfer gstnvinfer_impl.cpp:311:notifyLoadModelStatus:<primary_gie> [UID 1]: Load new model:/deepstream/Yolov5-in-Deepstream-5.0/Deepstream_5.0/config_infer_primary_yoloV5.txt sucessfully
Runtime commands:
        h: Print this help
        q: Quit
        p: Pause
        r: Resume
NOTE: To expand a source in the 2D tiled display and view object details, left-click on the source.
      To go back to the tiled display, right-click anywhere on the window.
** INFO: <bus_callback:181>: Pipeline ready
** INFO: <bus_callback:167>: Pipeline running
KLT Tracker Init
OpenCV Error: Assertion failed (0 <= roi.x && 0 <= roi.width && roi.x + roi.width <= m.cols && 0 <= roi.y && 0 <= roi.height && roi.y + roi.height <= m.rows) in Mat, file /opencv-3.4.0/modules/core/src/matrix.cpp, line 538
An exception occurred. /opencv-3.4.0/modules/core/src/matrix.cpp:538: error: (-215) 0 <= roi.x && 0 <= roi.width && roi.x + roi.width <= m.cols && 0 <= roi.y && 0 <= roi.height && roi.y + roi.height <= m.rows in function Mat
^C** ERROR: <_intr_handler:140>: User Interrupted..
Quitting
Hi @neos2008,
Could you help set “enable=1” of [tracker] to “enable=0” to check if you still see these errors?
From the “1 OUTPUT kFLOAT prob 6001x1x1”, yolov5 is just a classification network, right?
When seting “enable=0” of [tracker] , deepstream app works correctly.
And yolov5 is a detection network.
@mchi
Hi @neos2008,
Could you use gdb to run your application and capture the backtrace when the error happen?
I fail to use gdb to run the application and capture the backtrace, when the error happen.
Could you share the repo?
Could you dump the BBOX coordinates to check if there is any BBOX over the frame region?
