Sorry for a late reply,
trying to do some test, btw, you could refer to this topic, Low camera frame rate
hope you could have some findings. and will update once progress.
It didn’t contain “interval” discussion in “Low camera frame rate”.
I repeat my question again.
<<case 2>>
The interval of primary-gie set 1.
[primary-gie]
enable=1
gpu-id=0
#model-engine-file=model_b1_int8.engine
labelfile-path=labels.txt
batch-size=1 #Required by the app for OSD, not a plugin property
bbox-border-color0=1;0;0;1
bbox-border-color1=0;1;1;1
bbox-border-color2=0;0;1;1
bbox-border-color3=0;1;0;1 interval=1
gie-unique-id=1
nvbuf-memory-type=0
config-file=config_infer_primary_yoloV3.txt
The deepstream-app also show FPS 22.
I have problem about case 2.
“Number of consecutive batches to skip for inference” is the define of interval.
Does it mean only max 11 frame for inference when interval 1?
Why the FPS is 22 about case 2?
