I have installed Deepstream properly through NGC container. However when I am trying to run the deepstream-app passing configuration file as a parameter, I get an error :bash: deepstream-app: command not found.
Request kindly help
The DeepStream IoT container extends the base container to include the DeepStream test5 application along with associated configs and models. If you want to use deepstream-app, we suggest your use the devel docker.
