deepak
July 21, 2020, 4:33am
1
• Hardware Platform (GeForce RTX 2080i)
• DeepStream Version 5.0-DP
• TensorRT Version 7
• NVIDIA GPU Driver Version 450.36.06 CUDA Version: 10.2
deepstream-app crashes if osd or tracker is disabled in the config file.
Use any standard config file provided with the sample deepstream-app and set osd or tracker property enable=0 to reproduce.
Amycao
July 22, 2020, 12:47pm
3
I can not repro your issue, could you please provide more information, like where it crashed, it’s hard to tell where get wrong without log.
deepak
August 10, 2020, 1:31pm
5
Amycao
August 25, 2020, 10:15am
7
I see you make some changes.
and i can not comile, anything wrong?
++ -g -c -o …/apps-common/src/deepstream_streammux.o -DPLATFORM_TEGRA -Wno-c+±compat -fpermissive -g -I…/apps-common/includes -I…/includes -DDS_VERSION_MINOR=0 -DDS_VERSION_MAJOR=5 pkg-config --cflags gstreamer-1.0 gstreamer-video-1.0 x11
…/apps-common/src/deepstream_streammux.c
cc1plus: warning: command line option ‘-Wno-c+±compat’ is valid for C/ObjC but not for C++
g++ -g -o deepstream-app deepstream_app.o deepstream_app_main.o deepstream_app_config_parser.o …/apps-common/src/deepstream_tracker_bin.o …/apps-common/src/deepstream_primary_gie_bin.o …/apps-common/src/deepstream_source_bin.o …/apps-common/src/deepstream_c2d_msg.o …/apps-common/src/deepstream_config_file_parser.o …/apps-common/src/deepstream_common.o …/apps-common/src/deepstream_sink_bin.o …/apps-common/src/deepstream_perf.o …/apps-common/src/deepstream_dewarper_bin.o …/apps-common/src/deepstream_dsexample.o …/apps-common/src/deepstream_secondary_gie_bin.o …/apps-common/src/deepstream_tiled_display_bin.o …/apps-common/src/deepstream_osd_bin.o …/apps-common/src/deepstream_streammux.o -L…/lib/ -lnvdsgst_meta -lnvds_meta -lnvdsgst_helper -lnvdsgst_smartrecord -lnvds_utils -lm -lgstrtspserver-1.0 -ldl -Wl,-rpath,…/lib/ pkg-config --libs gstreamer-1.0 gstreamer-video-1.0 x11
/usr/bin/ld: deepstream_app.o: Relocations in generic ELF (EM: 62)
deepstream_app.o: error adding symbols: File in wrong format
collect2: error: ld returned 1 exit status
Makefile:59: recipe for target ‘deepstream-app’ failed
make: *** [deepstream-app] Error 1
Can you repro your issue with original sample?
deepak
August 26, 2020, 4:30am
8
As far as I remember, this issue had occurred even with the original deepstream-app sample. You can try using the original deepstream-app to reproduce. I have not tried to reproduce it again with the original sample.
Amycao
August 27, 2020, 2:34am
9
But I can not repro your issue using original sample.
