I’m experimenting on a Jetson Nano, with a deepstream-app and I would like to use a RTSP sink as output:
[sink0]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File 4=RTSPStreaming
type=4
#1=h264 2=h265
codec=1
sync=0
bitrate=1000000
# set below properties in case of RTSPStreaming
rtsp-port=8554
udp-port=6666
The problem with this configuration is that, even when there is no RTSP client connected, the video stream is sent on UDP on a the broadcast address (224.224.255.255).
Unfortunately, the UDP stream produced by the Jetson Nano causes delays in my network. For this reason, I would really like to disable UDP streaming, and use RTSP just on TCP.
So far, I tried to comment out to the udp-port property, and to set it to -1 or 0. None of these seems to work: the UDP data is still streamed on some default port.
The app I’m using right now is a very simple one:
- MIPI CSI camera used as a Source
- RTSP used as Sink
The full config used is:
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=5
#gie-kitti-output-dir=streamscl
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI 4=RTSP 5=CSI
type=5
camera-csi-sensor-id=0
camera-width=1280
camera-height=720
camera-fps-n=30
camera-fps-d=1
drop-frame-interval=1
gpu-id=0
# (0): memtype_device - Memory type Device
# (1): memtype_pinned - Memory type Host Pinned
# (2): memtype_unified - Memory type Unified
cudadec-memtype=0
[sink0]
enable=1
type=4
#1=h264 2=h265
codec=1
sync=0
bitrate=1000000
#bitrate=4000000
rtsp-port=8554
udp-port=6666
[streammux]
gpu-id=0
##Boolean property to inform muxer that sources are live
live-source=0
batch-size=1
##time out in usec, to wait after the first buffer is available
##to push the batch even if the complete batch is not formed
batched-push-timeout=40000
## Set muxer output width and height
#width=1920
#height=1080
width=1280
height=720
##Enable to maintain aspect ratio wrt source, and allow black borders, works
##along with width, height properties
enable-padding=0
nvbuf-memory-type=0
[tests]
file-loop=0
I would really appreciate some help with this!
Thanks,
Attila
