Deepstream-app elements order of placement
A general enquiry on deepstream-app
What is the other of elements if I were to enable through configuration file?
Example if enable ds-example or nvdsanalytics, how do i know at which part of the pipeline would it be placed? Can i change the order of the elements through the config file?
No. You can check create_pipeline() in deepstream-app.
Thanks for the reply. Seems like very much a developer would need to analyze the codes to find out how things work for deepstream. Which means actually the samples are not good enough for typical use-cases
