Hi! I used docker to pull a deepstream-l4t image from NVIDIA NGC ,
and it’s a sample-version.
the pull command is
“docker pull nvcr.io/nvidia/deepstream-l4t:5.1-21.02-samples ”.
When I enter the samples directory and execute
deepstream-app -c ./configs/deepstream-app/source30_1080p_dec_infer-resnet_tiled_display_int8.txt
i get the error
deepstream-app: error while loading shared libraries: /usr/lib/aarch64-linux-gnu/libnvinfer.so.7: file too short
Please help!! I’m a beginner and barely know of deepstream.
It seems like the path error, you can try this command in the config dir and use the absolute path to execute the deepsteam-app
Hi, 936214531!
I tried the command 'deepstream-app -c /opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app/source30_1080p_dec_infer-resnet_tiled_display_int8.txt‘ in the config dir, but I got the same error.
It seems like wherever I try the command ‘deepstream-app’, the error comes.
root@xxxxx:/opt/nvidia/deepstream/deepstream-5.1/samples/configs/deepstream-app$ /opt/nvidia/deepstream/deepstream-5.1/bin/deepstream-app -c source30_1080p_dec_infer-resnet_tiled_display_int8.txt
It works in my environment, At least no error like you.
Thanks for your reply.
I tried the command, it didn’t work in my environment.
I download and extract the image on Win10(x64), could it be a problem?
bcao
July 27, 2021, 10:29am
#13
The problem is that I pull and extract the image on x86-64, which caused the file damage.
bcao
August 2, 2021, 1:40am
#16
Great, let’s close this topic.
system
closed
October 9, 2021, 1:18am
#18
