Deepstream-app not displaying any window
I use Jetson AGX Xavier, Jetpack 4.6, deepstream 6.0.
When running the: deepstram-app -c source1_csi_dec_infer_resnet_int8.txt
no window appears.
Solved!
Thanks for the update, would you please share how to resolve the issue?
Hello.
The solution was very simple:
I manually edited the source1_csi_dec_infer_resnet_int8.txt file.
In the [sink0] paragraph set
width=1920
height=1080
in the original files they were equal to 0.
The different “sinkS” are actually the outputs.
P.S.
Obviously there is an internal convention at Nvidia about the source code and the config files and it takes some time to an external developer to get used to it.
