GPU
• DeepStream Version
6.1.1
• TensorRT Version
pipeline.txt (1.5 KB)
deepstream-app -c pipeline.txt
The inference model uses yolov5,The picture is my graphics card resource usage
This is a bug in version 6.1, Please update to version6.2
With your config file, It’s can works as expected.
update to version6.2 ,These problems do not occur with the resnet10 model in the sdk, but they still occur with the yolo model
deepstream-app -c /opt/nvidia/deepstream/deepstream-6.2/sources/objectDetector_Yolo/deepstream_app_config_yoloV2.txt
The results are as follows:
I think it’s a new bug.
If you modify value of gpu-id from 0 to 3(if you have more than 4 GPUS) in deepstream_app_config_yoloV3.txt
and config_infer_primary_yoloV3.txt
The bug will be occur
But in config_infer_primary_yoloV2.txt
if you use gpu-id=0 like deepstream_app_config_yoloV2.txt
. It’s will be ok.
There is a workaround.
set all gpu-id=0 and set export CUDA_VISIBLE_DEVICES=gpu id which you want run program on it
before program execution
We will look into this issue and will be back once there is any progress.
