• Hardware Platform (Jetson / GPU): Jetson AGX Xavier
• DeepStream Version: 5.0
• JetPack Version (valid for Jetson only): 4.4
• TensorRT Version: TensorRT 7.1.3
• Issue Type( questions, new requirements, bugs):questions/bugs
Hi, I am running a deepstream-app
pipeline with config files attached here.
ds_app_config_4ch_yoloV3.txt (5.2 KB)
I was streaming four 10-hr videos sources from an external hard drive and enabled the ‘file-loop = 1’ at the bottom of config, in order to let it start over once the videos come to their end. It’s been running normally for the past 7 days, but today the pipeline threw out an exception. It stopped as follows:
ERROR: Failed to synchronize on cuda copy-coplete-event, cuda err_no:6, err_str:cudaErrorLaunchTimeout
109:50:03.492845088 23957 0x16f69590 WARN nvinfer gstnvinfer.cpp:2012:gst_nvinfer_output_loop:<primary_gie> error: Failed to dequeue output from inferencing. NvDsInferContext error: NVDSINFER_CUDA_ERROR
ERROR from primary_gie: Failed to dequeue output from inferencing. NvDsInferContext error: NVDSINFER_CUDA_ERROR
Debug info: /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvinfer/gstnvinfer.cpp(2012): gst_nvinfer_output_loop (): /GstPipeline:pipeline/GstBin:primary_gie_bin/GstNvInfer:primary_gie
109:50:03.494806368 23957 0x16f69590 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::releaseBatchOutput() <nvdsinfer_context_impl.cpp:1606> [UID = 1]: Tried to release an outputBatchID which is already with the context
Quitting
109:50:03.515479392 23957 0x16f69590 WARN nvinfer gstnvinfer.cpp:2012:gst_nvinfer_output_loop:<primary_gie> error: Failed to dequeue output from inferencing. NvDsInferContext error: NVDSINFER_CUDA_ERROR
109:50:03.515576128 23957 0x16f69590 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::releaseBatchOutput() <nvdsinfer_context_impl.cpp:1606> [UID = 1]: Tried to release an outputBatchID which is already with the context
109:50:03.524366176 23957 0x170889e0 ERROR nvinfer gstnvinfer.cpp:1103:get_converted_buffer:<primary_gie> cudaMemset2DAsync failed with error cudaErrorLaunchTimeout while converting buffer
109:50:03.524570048 23957 0x170889e0 WARN nvinfer gstnvinfer.cpp:1363:gst_nvinfer_process_full_frame:<primary_gie> error: Buffer conversion failed
ERROR: [TRT]: ../rtSafe/safeContext.cpp (133) - Cudnn Error in configure: 7 (CUDNN_STATUS_MAPPING_ERROR)
ERROR: [TRT]: FAILED_EXECUTION: std::exception
ERROR: Failed to enqueue trt inference batch
ERROR: Infer context enqueue buffer failed, nvinfer error:NVDSINFER_TENSORRT_ERROR
109:50:03.564645824 23957 0x16fb80f0 WARN nvinfer gstnvinfer.cpp:1216:gst_nvinfer_input_queue_loop:<primary_gie> error: Failed to queue input batch for inferencing
ERROR: Failed to make stream wait on event, cuda err_no:6, err_str:cudaErrorLaunchTimeout
ERROR: Preprocessor transform input data failed., nvinfer error:NVDSINFER_CUDA_ERROR
109:50:03.564916672 23957 0x16fb80f0 WARN nvinfer gstnvinfer.cpp:1216:gst_nvinfer_input_queue_loop:<primary_gie> error: Failed to queue input batch for inferencing
ERROR from primary_gie: Buffer conversion failed
Debug info: /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvinfer/gstnvinfer.cpp(1363): gst_nvinfer_process_full_frame (): /GstPipeline:pipeline/GstBin:primary_gie_bin/GstNvInfer:primary_gie
ERROR from primary_gie: Failed to queue input batch for inferencing
Debug info: /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvinfer/gstnvinfer.cpp(1216): gst_nvinfer_input_queue_loop (): /GstPipeline:pipeline/GstBin:primary_gie_bin/GstNvInfer:primary_gie
I am also attaching the Nvidia bug report log here:
nvidia-bug-report-tegra.log (322.9 KB)
It looks like errors coming from inside of CUDA. Would you mind telling me what’s going on here and how can I fix it? Thank you!
