Deepstream-audio input hls(.m3u8) failed
I am trying to modify deepstream-audio sample to analyze audio from hls input(.m3u8)
I simply changed uri of ds_audio_sonyc_rtsp_test_config.txt to my test uri.
While it failed to run and below is the running pipeline.
Before this one, I succeed to run video sample w/ hls as input. That’s why I think audio should work as well.
Any hint or suggestion would be appreciated :-)
• Hardware Platform (Jetson / GPU) T4
• DeepStream Version 5.1
• TensorRT Version w/ offical deepstream docker
• NVIDIA GPU Driver Version (valid for GPU only) 450.80.02
• Issue Type( questions, new requirements, bugs) question/bug?
**logs
** WARN: <create_pipeline:382>: [audio-classifier] audio-input-rate config key not configured; falling back to default: 44.1kHz
(deepstream-audio:4562): GLib-GObject-WARNING **: 03:59:21.886: g_object_set_is_valid_property: object class ‘GstNvStreamMux’ has no property named ‘gpu-id’
(deepstream-audio:4562): GLib-GObject-WARNING **: 03:59:21.886: g_object_set_is_valid_property: object class ‘GstNvStreamMux’ has no property named ‘nvbuf-memory-type’
(deepstream-audio:4562): GLib-GObject-WARNING **: 03:59:21.886: g_object_set_is_valid_property: object class ‘GstNvStreamMux’ has no property named ‘live-source’
(deepstream-audio:4562): GLib-GObject-WARNING **: 03:59:21.886: g_object_set_is_valid_property: object class ‘GstNvStreamMux’ has no property named ‘batched-push-timeout’
(deepstream-audio:4562): GLib-GObject-WARNING **: 03:59:21.886: g_object_set_is_valid_property: object class ‘GstNvStreamMux’ has no property named ‘enable-padding’
max_fps_dur 8.33333e+06 min_fps_dur 2e+08
INFO: …/nvdsinfer/nvdsinfer_model_builder.cpp:685 [FullDims Engine Info]: layers num: 2
0 INPUT kFLOAT input.1 1x635x128 min: 1x1x635x128 opt: 2x1x635x128 Max: 2x1x635x128
1 OUTPUT kFLOAT output1 31 min: 0 opt: 0 Max: 0
Runtime commands:
h: Print this help
q: Quit
p: Pause
r: Resume
** INFO: <bus_callback:137>: Pipeline ready
0:00:01.821006168 [333m 4562[00m 0x55a8dcccd280 [36mINFO [00m [00m hlsdemux gsthlsdemux.c:613:gst_hls_demux_process_manifest:[00m Initial playlist location: http://devimages.apple.com/iphone/samples/bipbop/gear4/prog_index.m3u8 (base uri: (null))
0:00:01.821014849 [333m 4562[00m 0x55a8dcccd320 [36mINFO [00m [00m hlsdemux gsthlsdemux.c:613:gst_hls_demux_process_manifest:[00m Initial playlist location: http://devimages.apple.com/iphone/samples/bipbop/gear4/prog_index.m3u8 (base uri: (null))
0:00:01.821070372 [333m 4562[00m 0x55a8dcccd280 [36mINFO [00m [00m hlsdemux gsthlsdemux.c:645:gst_hls_demux_process_manifest:[00m selected http://devimages.apple.com/iphone/samples/bipbop/gear4/prog_index.m3u8
0:00:01.821088387 [333m 4562[00m 0x55a8dcccd320 [36mINFO [00m [00m hlsdemux gsthlsdemux.c:645:gst_hls_demux_process_manifest:[00m selected http://devimages.apple.com/iphone/samples/bipbop/gear4/prog_index.m3u8
0:00:01.821267796 [333m 4562[00m 0x7f6bb8530f70 [37mDEBUG [00m [00m hlsdemux gsthlsdemux.c:1109:gst_hls_demux_update_fragment_info:[00m Stream 0x7f6bb84a02a0 URI now http://xx0000000.ts
0:00:01.821273328 [333m 4562[00m 0x7f6bac031720 [37mDEBUG [00m [00m hlsdemux gsthlsdemux.c:1109:gst_hls_demux_update_fragment_info:[00m Stream 0x7f6bac016430 URI now http://xx0000000.ts
0:00:01.830704559 [333m 4562[00m 0x7f6b80012400 [37mDEBUG [00m [00m hlsdemux gsthlsdemux.c:851:gst_hls_demux_handle_buffer:[00m Typefind result: video/mpegts, systemstream=(boolean)true, packetsize=(int)188 prob:100
0:00:01.830734639 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:225:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m TS packet start offset: 0
0:00:01.830739610 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:240:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0000 (PAT)
0:00:01.830744716 [333m 4562[00m 0x7f6b80012400 [37mDEBUG [00m [00m hlsdemux gsthlsdemux-util.c:173:handle_pat:[00m program 0001: pmt_pid : 1000
0:00:01.830750020 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:246:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 1000 (PMT)
0:00:01.830754616 [333m 4562[00m 0x7f6b80012400 [37mDEBUG [00m [00m hlsdemux gsthlsdemux-util.c:139:handle_pmt:[00m pcr_pid now: 0100
0:00:01.830766581 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.830772266 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:106:handle_pcr:[00m have PCR! 0 0:00:00.000000000
0:00:01.831679554 [333m 4562[00m 0x7f6bac031940 [37mDEBUG [00m [00m hlsdemux gsthlsdemux.c:851:gst_hls_demux_handle_buffer:[00m Typefind result: video/mpegts, systemstream=(boolean)true, packetsize=(int)188 prob:100
0:00:01.831705897 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:225:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m TS packet start offset: 0
0:00:01.831710910 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:240:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0000 (PAT)
0:00:01.831717594 [333m 4562[00m 0x7f6bac031940 [37mDEBUG [00m [00m hlsdemux gsthlsdemux-util.c:173:handle_pat:[00m program 0001: pmt_pid : 1000
0:00:01.831721573 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:246:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 1000 (PMT)
0:00:01.831725149 [333m 4562[00m 0x7f6bac031940 [37mDEBUG [00m [00m hlsdemux gsthlsdemux-util.c:139:handle_pmt:[00m pcr_pid now: 0100
0:00:01.831728684 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.831733799 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:106:handle_pcr:[00m have PCR! 0 0:00:00.000000000
0:00:01.832003964 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:225:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m TS packet start offset: 74
0:00:01.832018339 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.832025182 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.832030539 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.832035308 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:240:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0000 (PAT)
0:00:01.832041227 [333m 4562[00m 0x7f6b80012400 [37mDEBUG [00m [00m hlsdemux gsthlsdemux-util.c:173:handle_pat:[00m program 0001: pmt_pid : 1000
0:00:01.832046770 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:246:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 1000 (PMT)
0:00:01.832051992 [333m 4562[00m 0x7f6b80012400 [37mDEBUG [00m [00m hlsdemux gsthlsdemux-util.c:139:handle_pmt:[00m pcr_pid now: 0100
0:00:01.832057054 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.832064223 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:106:handle_pcr:[00m have PCR! 4077000 0:00:00.151000000
0:00:01.832385830 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:225:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m TS packet start offset: 73
0:00:01.832411458 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.832425159 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.832440393 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:225:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m TS packet start offset: 95
0:00:01.832446320 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.832451401 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:240:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0000 (PAT)
0:00:01.832457666 [333m 4562[00m 0x7f6bac031940 [37mDEBUG [00m [00m hlsdemux gsthlsdemux-util.c:173:handle_pat:[00m program 0001: pmt_pid : 1000
0:00:01.832462999 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:246:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 1000 (PMT)
0:00:01.832468162 [333m 4562[00m 0x7f6bac031940 [37mDEBUG [00m [00m hlsdemux gsthlsdemux-util.c:139:handle_pmt:[00m pcr_pid now: 0100
0:00:01.832473396 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.832480961 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:106:handle_pcr:[00m have PCR! 4077000 0:00:00.151000000
0:00:01.837161416 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:225:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m TS packet start offset: 124
0:00:01.837174312 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.837178520 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.837183540 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.837186847 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.837195723 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:225:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m TS packet start offset: 32
0:00:01.837199324 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.837202666 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.838444303 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:225:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m TS packet start offset: 52
0:00:01.838450650 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.838454323 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.838457825 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.838471095 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:225:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m TS packet start offset: 104
0:00:01.838474727 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.838478052 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.839325730 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:225:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m TS packet start offset: 167
0:00:01.839337722 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.839341940 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.839345529 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.839349002 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.839352471 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.839357855 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.839702214 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:225:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m TS packet start offset: 168
0:00:01.839710107 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.839715045 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.839720240 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.839723767 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.839734307 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:225:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m TS packet start offset: 32
0:00:01.839739240 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.839742651 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.840729237 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:225:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m TS packet start offset: 103
0:00:01.840737330 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.840741586 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.840750800 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.840759208 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:225:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m TS packet start offset: 3
0:00:01.840762685 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.840766040 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.840769435 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.841454703 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:225:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m TS packet start offset: 23
0:00:01.841461591 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.841465616 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.846912455 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:225:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m TS packet start offset: 183
0:00:01.846919261 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.846923469 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.846927435 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.846931405 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.846939879 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:225:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m TS packet start offset: 39
0:00:01.846943322 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.846946619 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.846949894 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.872818256 [333m 4562[00m 0x55a8dc98ea80 [33;01mWARN [00m [00m v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink[00m Unable to try format: Unknown error -1
0:00:01.872822148 [333m 4562[00m 0x55a8dc9cdd90 [33;01mWARN [00m [00m v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink[00m Unable to try format: Unknown error -1
0:00:01.872840853 [333m 4562[00m 0x55a8dc98ea80 [33;01mWARN [00m [00m v4l2 gstv4l2object.c:2924:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink[00m Could not probe minimum capture size for pixelformat MJPG
0:00:01.872866289 [333m 4562[00m 0x55a8dc9cdd90 [33;01mWARN [00m [00m v4l2 gstv4l2object.c:2924:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink[00m Could not probe minimum capture size for pixelformat MJPG
0:00:01.872876588 [333m 4562[00m 0x55a8dc98ea80 [33;01mWARN [00m [00m v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink[00m Unable to try format: Unknown error -1
0:00:01.872891659 [333m 4562[00m 0x55a8dc9cdd90 [33;01mWARN [00m [00m v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink[00m Unable to try format: Unknown error -1
0:00:01.872901188 [333m 4562[00m 0x55a8dc98ea80 [33;01mWARN [00m [00m v4l2 gstv4l2object.c:2930:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink[00m Could not probe maximum capture size for pixelformat MJPG
0:00:01.872923268 [333m 4562[00m 0x55a8dc9cdd90 [33;01mWARN [00m [00m v4l2 gstv4l2object.c:2930:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink[00m Could not probe maximum capture size for pixelformat MJPG
0:00:01.872930142 [333m 4562[00m 0x55a8dc98ea80 [33;01mWARN [00m [00m v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink[00m Unable to try format: Unknown error -1
0:00:01.872937895 [333m 4562[00m 0x55a8dc98ea80 [33;01mWARN [00m [00m v4l2 gstv4l2object.c:2924:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink[00m Could not probe minimum capture size for pixelformat MPG4
0:00:01.872940908 [333m 4562[00m 0x55a8dc9cdd90 [33;01mWARN [00m [00m v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink[00m Unable to try format: Unknown error -1
0:00:01.872949679 [333m 4562[00m 0x55a8dc9cdd90 [33;01mWARN [00m [00m v4l2 gstv4l2object.c:2924:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink[00m Could not probe minimum capture size for pixelformat MPG4
0:00:01.872942023 [333m 4562[00m 0x55a8dc98ea80 [33;01mWARN [00m [00m v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink[00m Unable to try format: Unknown error -1
0:00:01.872966361 [333m 4562[00m 0x55a8dc98ea80 [33;01mWARN [00m [00m v4l2 gstv4l2object.c:2930:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink[00m Could not probe maximum capture size for pixelformat MPG4
0:00:01.872958552 [333m 4562[00m 0x55a8dc9cdd90 [33;01mWARN [00m [00m v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink[00m Unable to try format: Unknown error -1
0:00:01.872979162 [333m 4562[00m 0x55a8dc98ea80 [33;01mWARN [00m [00m v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink[00m Unable to try format: Unknown error -1
0:00:01.872987736 [333m 4562[00m 0x55a8dc98ea80 [33;01mWARN [00m [00m v4l2 gstv4l2object.c:2924:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink[00m Could not probe minimum capture size for pixelformat MPG2
0:00:01.872994385 [333m 4562[00m 0x55a8dc98ea80 [33;01mWARN [00m [00m v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink[00m Unable to try format: Unknown error -1
0:00:01.872981691 [333m 4562[00m 0x55a8dc9cdd90 [33;01mWARN [00m [00m v4l2 gstv4l2object.c:2930:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink[00m Could not probe maximum capture size for pixelformat MPG4
0:00:01.873005599 [333m 4562[00m 0x55a8dc98ea80 [33;01mWARN [00m [00m v4l2 gstv4l2object.c:2930:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink[00m Could not probe maximum capture size for pixelformat MPG2
0:00:01.873015912 [333m 4562[00m 0x55a8dc9cdd90 [33;01mWARN [00m [00m v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink[00m Unable to try format: Unknown error -1
0:00:01.873020625 [333m 4562[00m 0x55a8dc98ea80 [33;01mWARN [00m [00m v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink[00m Unable to try format: Unknown error -1
0:00:01.873029923 [333m 4562[00m 0x55a8dc9cdd90 [33;01mWARN [00m [00m v4l2 gstv4l2object.c:2924:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink[00m Could not probe minimum capture size for pixelformat MPG2
0:00:01.873045977 [333m 4562[00m 0x55a8dc9cdd90 [33;01mWARN [00m [00m v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink[00m Unable to try format: Unknown error -1
0:00:01.873053139 [333m 4562[00m 0x55a8dc9cdd90 [33;01mWARN [00m [00m v4l2 gstv4l2object.c:2930:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink[00m Could not probe maximum capture size for pixelformat MPG2
0:00:01.873037367 [333m 4562[00m 0x55a8dc98ea80 [33;01mWARN [00m [00m v4l2 gstv4l2object.c:2924:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink[00m Could not probe minimum capture size for pixelformat H265
0:00:01.873066457 [333m 4562[00m 0x55a8dc9cdd90 [33;01mWARN [00m [00m v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink[00m Unable to try format: Unknown error -1
0:00:01.873074596 [333m 4562[00m 0x55a8dc9cdd90 [33;01mWARN [00m [00m v4l2 gstv4l2object.c:2924:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink[00m Could not probe minimum capture size for pixelformat H265
0:00:01.873081274 [333m 4562[00m 0x55a8dc9cdd90 [33;01mWARN [00m [00m v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink[00m Unable to try format: Unknown error -1
0:00:01.873088422 [333m 4562[00m 0x55a8dc9cdd90 [33;01mWARN [00m [00m v4l2 gstv4l2object.c:2930:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink[00m Could not probe maximum capture size for pixelformat H265
0:00:01.873066906 [333m 4562[00m 0x55a8dc98ea80 [33;01mWARN [00m [00m v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink[00m Unable to try format: Unknown error -1
0:00:01.873102706 [333m 4562[00m 0x55a8dc98ea80 [33;01mWARN [00m [00m v4l2 gstv4l2object.c:2930:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink[00m Could not probe maximum capture size for pixelformat H265
0:00:01.873102709 [333m 4562[00m 0x55a8dc9cdd90 [33;01mWARN [00m [00m v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink[00m Unable to try format: Unknown error -1
0:00:01.873114631 [333m 4562[00m 0x55a8dc98ea80 [33;01mWARN [00m [00m v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink[00m Unable to try format: Unknown error -1
0:00:01.873123037 [333m 4562[00m 0x55a8dc98ea80 [33;01mWARN [00m [00m v4l2 gstv4l2object.c:2924:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink[00m Could not probe minimum capture size for pixelformat VP90
0:00:01.873129725 [333m 4562[00m 0x55a8dc98ea80 [33;01mWARN [00m [00m v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink[00m Unable to try format: Unknown error -1
0:00:01.873136786 [333m 4562[00m 0x55a8dc98ea80 [33;01mWARN [00m [00m v4l2 gstv4l2object.c:2930:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink[00m Could not probe maximum capture size for pixelformat VP90
0:00:01.873147419 [333m 4562[00m 0x55a8dc98ea80 [33;01mWARN [00m [00m v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink[00m Unable to try format: Unknown error -1
0:00:01.873148271 [333m 4562[00m 0x55a8dc9cdd90 [33;01mWARN [00m [00m v4l2 gstv4l2object.c:2924:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink[00m Could not probe minimum capture size for pixelformat VP90
0:00:01.873167013 [333m 4562[00m 0x55a8dc9cdd90 [33;01mWARN [00m [00m v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink[00m Unable to try format: Unknown error -1
0:00:01.873156753 [333m 4562[00m 0x55a8dc98ea80 [33;01mWARN [00m [00m v4l2 gstv4l2object.c:2924:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink[00m Could not probe minimum capture size for pixelformat VP80
0:00:01.873176204 [333m 4562[00m 0x55a8dc9cdd90 [33;01mWARN [00m [00m v4l2 gstv4l2object.c:2930:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink[00m Could not probe maximum capture size for pixelformat VP90
0:00:01.873185490 [333m 4562[00m 0x55a8dc98ea80 [33;01mWARN [00m [00m v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink[00m Unable to try format: Unknown error -1
0:00:01.873196408 [333m 4562[00m 0x55a8dc9cdd90 [33;01mWARN [00m [00m v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink[00m Unable to try format: Unknown error -1
0:00:01.873211766 [333m 4562[00m 0x55a8dc9cdd90 [33;01mWARN [00m [00m v4l2 gstv4l2object.c:2924:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink[00m Could not probe minimum capture size for pixelformat VP80
0:00:01.873218666 [333m 4562[00m 0x55a8dc9cdd90 [33;01mWARN [00m [00m v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink[00m Unable to try format: Unknown error -1
0:00:01.873225873 [333m 4562[00m 0x55a8dc9cdd90 [33;01mWARN [00m [00m v4l2 gstv4l2object.c:2930:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink[00m Could not probe maximum capture size for pixelformat VP80
0:00:01.873203109 [333m 4562[00m 0x55a8dc98ea80 [33;01mWARN [00m [00m v4l2 gstv4l2object.c:2930:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink[00m Could not probe maximum capture size for pixelformat VP80
0:00:01.873237589 [333m 4562[00m 0x55a8dc9cdd90 [33;01mWARN [00m [00m v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink[00m Unable to try format: Unknown error -1
0:00:01.873247377 [333m 4562[00m 0x55a8dc9cdd90 [33;01mWARN [00m [00m v4l2 gstv4l2object.c:2924:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink[00m Could not probe minimum capture size for pixelformat H264
0:00:01.873253383 [333m 4562[00m 0x55a8dc9cdd90 [33;01mWARN [00m [00m v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink[00m Unable to try format: Unknown error -1
0:00:01.873256231 [333m 4562[00m 0x55a8dc98ea80 [33;01mWARN [00m [00m v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink[00m Unable to try format: Unknown error -1
0:00:01.873264815 [333m 4562[00m 0x55a8dc98ea80 [33;01mWARN [00m [00m v4l2 gstv4l2object.c:2924:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink[00m Could not probe minimum capture size for pixelformat H264
0:00:01.873271570 [333m 4562[00m 0x55a8dc98ea80 [33;01mWARN [00m [00m v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink[00m Unable to try format: Unknown error -1
0:00:01.873278397 [333m 4562[00m 0x55a8dc98ea80 [33;01mWARN [00m [00m v4l2 gstv4l2object.c:2930:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink[00m Could not probe maximum capture size for pixelformat H264
0:00:01.873257993 [333m 4562[00m 0x55a8dc9cdd90 [33;01mWARN [00m [00m v4l2 gstv4l2object.c:2930:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink[00m Could not probe maximum capture size for pixelformat H264
0:00:01.873631706 [333m 4562[00m 0x55a8dc98ea80 [33;01mWARN [00m [00m v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:src[00m Unable to try format: Unknown error -1
0:00:01.873635718 [333m 4562[00m 0x55a8dc9cdd90 [33;01mWARN [00m [00m v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:src[00m Unable to try format: Unknown error -1
0:00:01.873646201 [333m 4562[00m 0x55a8dc98ea80 [33;01mWARN [00m [00m v4l2 gstv4l2object.c:2924:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:src[00m Could not probe minimum capture size for pixelformat NM12
0:00:01.873659284 [333m 4562[00m 0x55a8dc9cdd90 [33;01mWARN [00m [00m v4l2 gstv4l2object.c:2924:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:src[00m Could not probe minimum capture size for pixelformat NM12
0:00:01.873667614 [333m 4562[00m 0x55a8dc9cdd90 [33;01mWARN [00m [00m v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:src[00m Unable to try format: Unknown error -1
0:00:01.873674456 [333m 4562[00m 0x55a8dc9cdd90 [33;01mWARN [00m [00m v4l2 gstv4l2object.c:2930:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:src[00m Could not probe maximum capture size for pixelformat NM12
0:00:01.873683793 [333m 4562[00m 0x55a8dc9cdd90 [33;01mWARN [00m [00m v4l2 gstv4l2object.c:2375:gst_v4l2_object_add_interlace_mode:0x7f6b1400fcf0[00m Failed to determine interlace mode
0:00:01.873685700 [333m 4562[00m 0x55a8dc98ea80 [33;01mWARN [00m [00m v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:src[00m Unable to try format: Unknown error -1
0:00:01.873698754 [333m 4562[00m 0x55a8dc98ea80 [33;01mWARN [00m [00m v4l2 gstv4l2object.c:2930:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:src[00m Could not probe maximum capture size for pixelformat NM12
0:00:01.873705410 [333m 4562[00m 0x55a8dc98ea80 [33;01mWARN [00m [00m v4l2 gstv4l2object.c:2375:gst_v4l2_object_add_interlace_mode:0x7f6b2000d4d0[00m Failed to determine interlace mode
0:00:01.983707965 [333m 4562[00m 0x55a8dc9cdd90 [31;01mERROR [00m [00m v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode:[00m Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:01.983725772 [333m 4562[00m 0x55a8dc9cdd90 [31;01mERROR [00m [00m v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode:[00m Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:01.983749490 [333m 4562[00m 0x55a8dc9cdd90 [31;01mERROR [00m [00m v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode:[00m Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:01.983754471 [333m 4562[00m 0x55a8dc9cdd90 [31;01mERROR [00m [00m v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode:[00m Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:01.983773685 [333m 4562[00m 0x55a8dc9cdd90 [31;01mERROR [00m [00m v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode:[00m Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:01.983778404 [333m 4562[00m 0x55a8dc9cdd90 [31;01mERROR [00m [00m v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode:[00m Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:01.983794814 [333m 4562[00m 0x55a8dc9cdd90 [31;01mERROR [00m [00m v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode:[00m Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:01.983799187 [333m 4562[00m 0x55a8dc9cdd90 [31;01mERROR [00m [00m v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode:[00m Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:01.983821684 [333m 4562[00m 0x55a8dc9cdd90 [31;01mERROR [00m [00m v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode:[00m Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:01.983826226 [333m 4562[00m 0x55a8dc9cdd90 [31;01mERROR [00m [00m v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode:[00m Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:01.983841480 [333m 4562[00m 0x55a8dc9cdd90 [31;01mERROR [00m [00m v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode:[00m Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:01.983845712 [333m 4562[00m 0x55a8dc9cdd90 [31;01mERROR [00m [00m v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode:[00m Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:01.983861953 [333m 4562[00m 0x55a8dc9cdd90 [31;01mERROR [00m [00m v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode:[00m Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:01.983866288 [333m 4562[00m 0x55a8dc9cdd90 [31;01mERROR [00m [00m v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode:[00m Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:01.983882133 [333m 4562[00m 0x55a8dc9cdd90 [31;01mERROR [00m [00m v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode:[00m Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:01.983886593 [333m 4562[00m 0x55a8dc9cdd90 [31;01mERROR [00m [00m v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode:[00m Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:01.984115315 [333m 4562[00m 0x55a8dc98ea80 [31;01mERROR [00m [00m v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode:[00m Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:01.984134072 [333m 4562[00m 0x55a8dc98ea80 [31;01mERROR [00m [00m v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode:[00m Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:01.984121842 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:225:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m TS packet start offset: 91
0:00:01.984156449 [333m 4562[00m 0x55a8dc98ea80 [31;01mERROR [00m [00m v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode:[00m Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:01.984163669 [333m 4562[00m 0x55a8dc98ea80 [31;01mERROR [00m [00m v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode:[00m Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:01.984157789 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.984175810 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.984181441 [333m 4562[00m 0x55a8dc98ea80 [31;01mERROR [00m [00m v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode:[00m Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:01.984187624 [333m 4562[00m 0x55a8dc98ea80 [31;01mERROR [00m [00m v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode:[00m Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:01.984181930 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.984212525 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.984213122 [333m 4562[00m 0x55a8dc98ea80 [31;01mERROR [00m [00m v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode:[00m Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:01.984227389 [333m 4562[00m 0x55a8dc98ea80 [31;01mERROR [00m [00m v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode:[00m Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:01.984251035 [333m 4562[00m 0x55a8dc98ea80 [31;01mERROR [00m [00m v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode:[00m Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:01.984255012 [333m 4562[00m 0x55a8dc98ea80 [31;01mERROR [00m [00m v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode:[00m Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:01.984268158 [333m 4562[00m 0x55a8dc98ea80 [31;01mERROR [00m [00m v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode:[00m Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:01.984271850 [333m 4562[00m 0x55a8dc98ea80 [31;01mERROR [00m [00m v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode:[00m Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:01.984285361 [333m 4562[00m 0x55a8dc98ea80 [31;01mERROR [00m [00m v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode:[00m Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:01.984289204 [333m 4562[00m 0x55a8dc98ea80 [31;01mERROR [00m [00m v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode:[00m Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:01.984303578 [333m 4562[00m 0x55a8dc98ea80 [31;01mERROR [00m [00m v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode:[00m Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:01.984307429 [333m 4562[00m 0x55a8dc98ea80 [31;01mERROR [00m [00m v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode:[00m Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:01.984345863 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:225:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m TS packet start offset: 43
0:00:01.984353916 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.984359506 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.984365188 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.984371212 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.984470554 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:225:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m TS packet start offset: 39
0:00:01.984477819 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.984483211 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.984488586 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.984522135 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:225:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m TS packet start offset: 96
0:00:01.984534134 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.984539560 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.984544633 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.984560521 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:225:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m TS packet start offset: 147
0:00:01.984568029 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.984573122 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.984581206 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.984588595 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.984596141 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.984572181 [333m 4562[00m 0x55a8dc9cdd90 [33;01mWARN [00m [00;01;31;41m GST_PADS gstpad.c:4226:gst_pad_peer_query:<src_elem:src_0>[00m could not send sticky events
0:00:01.984663862 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:225:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m TS packet start offset: 156
0:00:01.984671445 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.984679288 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.984686979 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.984696815 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.984700222 [333m 4562[00m 0x55a8dc9cdd90 [33;01mWARN [00m [00m v4l2videodec gstv4l2videodec.c:1673:gst_v4l2_video_dec_decide_allocation:[00m Duration invalid, not setting latency
0:00:01.984728251 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.984740346 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.984672981 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:225:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m TS packet start offset: 31
0:00:01.984762375 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.984770326 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.984777892 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.984787669 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:240:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0000 (PAT)
0:00:01.984793531 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:225:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m TS packet start offset: 176
0:00:01.984803731 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.984797523 [333m 4562[00m 0x7f6bac031940 [37mDEBUG [00m [00m hlsdemux gsthlsdemux-util.c:173:handle_pat:[00m program 0001: pmt_pid : 1000
0:00:01.984819850 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:246:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 1000 (PMT)
0:00:01.984830403 [333m 4562[00m 0x7f6bac031940 [37mDEBUG [00m [00m hlsdemux gsthlsdemux-util.c:139:handle_pmt:[00m pcr_pid now: 0100
0:00:01.984840469 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.984807922 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.984864875 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.984875816 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.984763505 [333m 4562[00m 0x55a8dc9cdd90 [33;01mWARN [00m [00m v4l2bufferpool gstv4l2bufferpool.c:1066:gst_v4l2_buffer_pool_start:nvv4l2decoder0:pool:src[00m Uncertain or not enough buffers, enabling copy threshold
0:00:01.984852975 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:106:handle_pcr:[00m have PCR! 78084000 0:00:02.892000000
0:00:01.984938893 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:225:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m TS packet start offset: 72
0:00:01.984946483 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.984952006 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.984965891 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.984959487 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:225:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m TS packet start offset: 103
0:00:01.984988028 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.984993623 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.984998352 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.985003490 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.985008636 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.985013620 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.985018926 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.985032956 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:225:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m TS packet start offset: 115
0:00:01.985038313 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.985041863 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.985045400 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.985048878 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.985124984 [333m 4562[00m 0x55a8dc98ea80 [33;01mWARN [00m [00;01;31;41m GST_PADS gstpad.c:4226:gst_pad_peer_query:<src_elem:src_0>[00m could not send sticky events
0:00:01.985160692 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:225:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m TS packet start offset: 136
0:00:01.985168504 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.985173758 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.985179023 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.985184956 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.985191279 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.985220380 [333m 4562[00m 0x55a8dc98ea80 [33;01mWARN [00m [00m v4l2videodec gstv4l2videodec.c:1673:gst_v4l2_video_dec_decide_allocation:[00m Duration invalid, not setting latency
0:00:01.985222674 [333m 4562[00m 0x55a8dc9ef8f0 [33;01mWARN [00m [00m basetransform gstbasetransform.c:1355:gst_base_transform_setcaps:<audioresampler_elem>[00m transform could not transform audio/x-raw, layout=(string)interleaved, rate=(int)48000, format=(string)F32LE, channels=(int)1, framerate=(fraction)0/1, width=(int)0, height=(int)0 in anything we support
0:00:01.985284017 [333m 4562[00m 0x55a8dc98ea80 [33;01mWARN [00m [00m v4l2bufferpool gstv4l2bufferpool.c:1066:gst_v4l2_buffer_pool_start:nvv4l2decoder1:pool:src[00m Uncertain or not enough buffers, enabling copy threshold
0:00:01.985300867 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:225:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m TS packet start offset: 23
0:00:01.985308752 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.985314190 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.985369310 [333m 4562[00m 0x55a8dc9ef8f0 [33;01mWARN [00m [00m basetransform gstbasetransform.c:1355:gst_base_transform_setcaps:<audioresampler_elem>[00m transform could not transform audio/x-raw, layout=(string)interleaved, rate=(int)48000, format=(string)F32LE, channels=(int)1, framerate=(fraction)0/1, width=(int)0, height=(int)0 in anything we support
0:00:01.985376481 [333m 4562[00m 0x55a8dc9ef8f0 [33;01mWARN [00m [00;01;31;41m GST_PADS gstpad.c:4226:gst_pad_peer_query:<audioconv_elem:src>[00m could not send sticky events
0:00:01.985403590 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:225:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m TS packet start offset: 80
0:00:01.985412658 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.985417977 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.985422963 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:240:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0000 (PAT)
0:00:01.985429477 [333m 4562[00m 0x7f6b80012400 [37mDEBUG [00m [00m hlsdemux gsthlsdemux-util.c:173:handle_pat:[00m program 0001: pmt_pid : 1000
0:00:01.985435208 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:246:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 1000 (PMT)
0:00:01.985440632 [333m 4562[00m 0x7f6b80012400 [37mDEBUG [00m [00m hlsdemux gsthlsdemux-util.c:139:handle_pmt:[00m pcr_pid now: 0100
0:00:01.985445688 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.985453924 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:106:handle_pcr:[00m have PCR! 78084000 0:00:02.892000000
0:00:01.985460462 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.985532619 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:225:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m TS packet start offset: 175
0:00:01.985543764 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.985551561 [333m 4562[00m 0x55a8dc9ef8f0 [33;01mWARN [00m [00m basetransform gstbasetransform.c:1355:gst_base_transform_setcaps:<audioresampler_elem>[00m transform could not transform audio/x-raw, layout=(string)interleaved, rate=(int)48000, format=(string)F32LE, channels=(int)1, framerate=(fraction)0/1, width=(int)0, height=(int)0 in anything we support
0:00:01.985535999 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:225:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m TS packet start offset: 185
0:00:01.985573394 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.985582081 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.985592170 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.985504681 [333m 4562[00m 0x7f6afc003de0 [33;01mWARN [00m [00m v4l2bufferpool gstv4l2bufferpool.c:1513:gst_v4l2_buffer_pool_dqbuf:nvv4l2decoder0:pool:src[00m Driver should never set v4l2_buffer.field to ANY
0:00:01.985600458 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.985643729 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.985651433 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.985659675 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.985666741 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.985675681 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.985689926 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.985698001 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.985703780 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.985710243 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.985711819 [333m 4562[00m 0x55a8dc98ead0 [33;01mWARN [00m [00m basetransform gstbasetransform.c:1355:gst_base_transform_setcaps:<audioresampler_elem>[00m transform could not transform audio/x-raw, layout=(string)interleaved, rate=(int)48000, format=(string)F32LE, channels=(int)1, framerate=(fraction)0/1, width=(int)0, height=(int)0 in anything we support
0:00:01.985771010 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:225:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m TS packet start offset: 121
0:00:01.985779742 [333m 4562[00m 0x55a8dc9ef8f0 [33;01mWARN [00m [00m basetransform gstbasetransform.c:1355:gst_base_transform_setcaps:<audioresampler_elem>[00m transform could not transform audio/x-raw, layout=(string)interleaved, rate=(int)48000, format=(string)F32LE, channels=(int)1, framerate=(fraction)0/1, width=(int)0, height=(int)0 in anything we support
0:00:01.985771382 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:225:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m TS packet start offset: 103
0:00:01.985801678 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.985809689 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.985819474 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.985803198 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.985837307 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.985843238 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.985848365 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.985877945 [333m 4562[00m 0x7f6b20313320 [33;01mWARN [00m [00m v4l2bufferpool gstv4l2bufferpool.c:1513:gst_v4l2_buffer_pool_dqbuf:nvv4l2decoder1:pool:src[00m Driver should never set v4l2_buffer.field to ANY
0:00:01.985921843 [333m 4562[00m 0x55a8dc98ead0 [33;01mWARN [00m [00m basetransform gstbasetransform.c:1355:gst_base_transform_setcaps:<audioresampler_elem>[00m transform could not transform audio/x-raw, layout=(string)interleaved, rate=(int)48000, format=(string)F32LE, channels=(int)1, framerate=(fraction)0/1, width=(int)0, height=(int)0 in anything we support
0:00:01.985931422 [333m 4562[00m 0x55a8dc98ead0 [33;01mWARN [00m [00;01;31;41m GST_PADS gstpad.c:4226:gst_pad_peer_query:<audioconv_elem:src>[00m could not send sticky events
0:00:01.985963836 [333m 4562[00m 0x55a8dc9ef8f0 [33;01mWARN [00m [00m basetransform gstbasetransform.c:1355:gst_base_transform_setcaps:<audioresampler_elem>[00m transform could not transform audio/x-raw, layout=(string)interleaved, rate=(int)48000, format=(string)F32LE, channels=(int)1, framerate=(fraction)0/1, width=(int)0, height=(int)0 in anything we support
0:00:01.986093894 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:225:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m TS packet start offset: 43
0:00:01.986102098 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.986107383 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.986113031 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.986115460 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:225:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m TS packet start offset: 153
0:00:01.986132119 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.986139633 [333m 4562[00m 0x55a8dc98ead0 [33;01mWARN [00m [00m basetransform gstbasetransform.c:1355:gst_base_transform_setcaps:<audioresampler_elem>[00m transform could not transform audio/x-raw, layout=(string)interleaved, rate=(int)48000, format=(string)F32LE, channels=(int)1, framerate=(fraction)0/1, width=(int)0, height=(int)0 in anything we support
** INFO: <bus_callback:123>: Pipeline running
0:00:01.986146182 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.986139605 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.986167111 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.986181083 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.986184567 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:225:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m TS packet start offset: 119
0:00:01.986195696 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.986186167 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.986214459 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.986218707 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.986222287 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.986230539 [333m 4562[00m 0x55a8dc9ef8f0 [33;01mWARN [00m [00m basetransform gstbasetransform.c:1355:gst_base_transform_setcaps:<audioresampler_elem>[00m transform could not transform audio/x-raw, layout=(string)interleaved, rate=(int)48000, format=(string)F32LE, channels=(int)1, framerate=(fraction)0/1, width=(int)0, height=(int)0 in anything we support
0:00:01.986244031 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:225:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m TS packet start offset: 117
0:00:01.986248568 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.986252007 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.986255458 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.986257763 [333m 4562[00m 0x55a8dc98ead0 [33;01mWARN [00m [00m basetransform gstbasetransform.c:1355:gst_base_transform_setcaps:<audioresampler_elem>[00m transform could not transform audio/x-raw, layout=(string)interleaved, rate=(int)48000, format=(string)F32LE, channels=(int)1, framerate=(fraction)0/1, width=(int)0, height=(int)0 in anything we support
0:00:01.986279196 [333m 4562[00m 0x7f6bac031940 [33;01mWARN [00m [00m adaptivedemux gstadaptivedemux.c:2651:_src_chain:[00m error: Internal data stream error.
0:00:01.986287591 [333m 4562[00m 0x7f6bac031940 [33;01mWARN [00m [00m adaptivedemux gstadaptivedemux.c:2651:_src_chain:[00m error: streaming stopped, reason not-negotiated (-4)
0:00:01.986295017 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:225:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m TS packet start offset: 25
0:00:01.986299950 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.986303444 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.986306875 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.986310773 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.986314511 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
ERROR from hlsdemux1: Internal data stream error.
0:00:01.986333396 [333m 4562[00m 0x7f6bac031940 [33;01mWARN [00m [00m queue gstqueue.c:1566:gst_queue_loop:[00m error: Internal data stream error.
0:00:01.986340739 [333m 4562[00m 0x7f6bac031940 [33;01mWARN [00m [00m queue gstqueue.c:1566:gst_queue_loop:[00m error: streaming stopped, reason not-negotiated (-4)
Debug info: gstadaptivedemux.c(2651): _src_chain (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin0/GstURIDecodeBin:src_elem/GstDecodeBin:decodebin0/GstHLSDemux:hlsdemux1:
0:00:01.986359843 [333m 4562[00m 0x55a8dc98ead0 [33;01mWARN [00m [00m basetransform gstbasetransform.c:1355:gst_base_transform_setcaps:<audioresampler_elem>[00m transform could not transform audio/x-raw, layout=(string)interleaved, rate=(int)48000, format=(string)F32LE, channels=(int)1, framerate=(fraction)0/1, width=(int)0, height=(int)0 in anything we support
0:00:01.986365893 [333m 4562[00m 0x7f6bac031940 [33;01mWARN [00m [00m adaptivedemux gstadaptivedemux.c:876:gst_adaptive_demux_handle_message:hlsdemux1:src_0[00m Source posted error: 3824:1 Internal data stream error. (gstqueue.c(1566): gst_queue_loop (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin0/GstURIDecodeBin:src_elem/GstDecodeBin:decodebin0/GstHLSDemux:hlsdemux1/GstBin:srcbin-src_0/GstQueue:queue0:
streaming stopped, reason not-negotiated (-4))
0:00:01.986420406 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:225:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m TS packet start offset: 157
0:00:01.986425118 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.986428546 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.986503781 [333m 4562[00m 0x7f6bb8530f70 [37mDEBUG [00m [00m hlsdemux gsthlsdemux.c:1109:gst_hls_demux_update_fragment_info:[00m Stream 0x7f6bb84a02a0 URI now http://xx0000000.ts
0:00:01.986538912 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:225:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m TS packet start offset: 161
0:00:01.986548212 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.986551804 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.986555136 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.986558829 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.986563483 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.986563678 [333m 4562[00m 0x55a8dc98ead0 [33;01mWARN [00m [00m basetransform gstbasetransform.c:1355:gst_base_transform_setcaps:<audioresampler_elem>[00m transform could not transform audio/x-raw, layout=(string)interleaved, rate=(int)48000, format=(string)F32LE, channels=(int)1, framerate=(fraction)0/1, width=(int)0, height=(int)0 in anything we support
0:00:01.986606691 [333m 4562[00m 0x7f6b80012400 [33;01mWARN [00m [00m adaptivedemux gstadaptivedemux.c:2651:_src_chain:[00m error: Internal data stream error.
0:00:01.986612757 [333m 4562[00m 0x7f6b80012400 [33;01mWARN [00m [00m adaptivedemux gstadaptivedemux.c:2651:_src_chain:[00m error: streaming stopped, reason not-negotiated (-4)
ERROR from hlsdemux0: Internal data stream error.
Debug info: gstadaptivedemux.c(2651): _src_chain (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin1/GstURIDecodeBin:src_elem/GstDecodeBin:decodebin1/GstHLSDemux:hlsdemux0:
0:00:01.986656896 [333m 4562[00m 0x7f6b80012400 [33;01mWARN [00m [00m queue gstqueue.c:1566:gst_queue_loop:[00m error: Internal data stream error.
0:00:01.986666592 [333m 4562[00m 0x7f6b80012400 [33;01mWARN [00m [00m queue gstqueue.c:1566:gst_queue_loop:[00m error: streaming stopped, reason not-negotiated (-4)
0:00:01.986686952 [333m 4562[00m 0x7f6b80012400 [33;01mWARN [00m [00m adaptivedemux gstadaptivedemux.c:876:gst_adaptive_demux_handle_message:hlsdemux0:src_0[00m Source posted error: 3824:1 Internal data stream error. (gstqueue.c(1566): gst_queue_loop (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin1/GstURIDecodeBin:src_elem/GstDecodeBin:decodebin1/GstHLSDemux:hlsdemux0/GstBin:srcbin-src_0/GstQueue:queue1:
0:00:01.986812392 [333m 4562[00m 0x7f6bac031720 [37mDEBUG [00m [00m hlsdemux gsthlsdemux.c:1109:gst_hls_demux_update_fragment_info:[00m Stream 0x7f6bac016430 URI now http://xx0000000.ts
0:00:01.995808725 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:225:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m TS packet start offset: 0
0:00:01.995814877 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:240:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0000 (PAT)
0:00:01.995819671 [333m 4562[00m 0x7f6b80012400 [37mDEBUG [00m [00m hlsdemux gsthlsdemux-util.c:173:handle_pat:[00m program 0001: pmt_pid : 1000
0:00:01.995823354 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:246:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 1000 (PMT)
0:00:01.995826814 [333m 4562[00m 0x7f6b80012400 [37mDEBUG [00m [00m hlsdemux gsthlsdemux-util.c:139:handle_pmt:[00m pcr_pid now: 0100
0:00:01.995834040 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.995839410 [333m 4562[00m 0x7f6b80012400 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:106:handle_pcr:[00m have PCR! 0 0:00:00.000000000
0:00:01.995844498 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:225:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m TS packet start offset: 0
0:00:01.995857535 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:240:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0000 (PAT)
0:00:01.995863248 [333m 4562[00m 0x7f6bac031940 [37mDEBUG [00m [00m hlsdemux gsthlsdemux-util.c:173:handle_pat:[00m program 0001: pmt_pid : 1000
0:00:01.995867389 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:246:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 1000 (PMT)
0:00:01.995871092 [333m 4562[00m 0x7f6bac031940 [37mDEBUG [00m [00m hlsdemux gsthlsdemux-util.c:139:handle_pmt:[00m pcr_pid now: 0100
0:00:01.995874856 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:252:gst_hlsdemux_tsreader_find_pcrs_mpegts:[00m Found packet for PID 0100 (PCR)
0:00:01.995882973 [333m 4562[00m 0x7f6bac031940 [33;01mLOG [00m [00m hlsdemux gsthlsdemux-util.c:106:handle_pcr:[00m have PCR! 0 0:00:00.000000000
Quitting
App run failed
You need to add capsfilter after the audio resample to tell it to convert the rate to 44100.
Thanks Fiona.
As you suggested, i manually added a capsfilter after resample to set rate to 44100.
The graph of pipeline seems good but it runs to another problem.
logs:
0:00:03.149031231 [336m 8207[00m 0x5582b76104a0 [33;01mWARN [00m [00m v4l2bufferpool gstv4l2bufferpool.c:1066:gst_v4l2_buffer_pool_start:nvv4l2decoder0:pool:src[00m Uncertain or not enough buffers, enabling copy threshold
0:00:03.149678422 [336m 8207[00m 0x7fb370006cf0 [33;01mWARN [00m [00m v4l2bufferpool gstv4l2bufferpool.c:1513:gst_v4l2_buffer_pool_dqbuf:nvv4l2decoder0:pool:src[00m Driver should never set v4l2_buffer.field to ANY
0:00:03.150957146 [336m 8207[00m 0x5582b7604400 [33;01mWARN [00m [00m videodecoder gstvideodecoder.c:2780:gst_video_decoder_prepare_finish_frame:[00m decreasing timestamp (0:00:00.050000000 < 0:00:00.151000000)
**PERF: FPS 0 (Avg)
**PERF: 0.00 (0.00)
It is for video part. You can just ignore it if you don’t need the video to be inferenced too.
I can ignore the video part. But the behavior of audio part is also abnormal.
It fails to print prediction like deepstream-audio sample( w/ .wav as input). Also, the perf shows FPS=0. Does it means the GIE still cannot receive frames of audio as required?
Basically, what I am doing is to check the graph of pipeline and debug log. However nothing else I can find to fix the issue :-(
I noticed that in the part of audio convert and resample. Audio params are entangled with redundant video ones.
It should be about this error in log:
<audio_capsfilter> transform could not transform audio/x-raw, layout=(string)interleaved, rate=(int)44100, format=(string)F32LE, channels=(int)1, framerate=(fraction)0/1, width=(int)0, height=(int)0 in anything we support.
From my understanding, one capsfilter can only apply limit for video or audio. Does this means entangled data stream is been processing or it is just a display bug which can be ignored?
Can you try to set the “enable-last-sample” property of fakesink to false?
Hi Fiona,
I set enable-last-sample to FALSE as you suggested. But it seems no different.
Also I try to manually set my wav to the same format like test wav and it can be read and give correct prediction.
Steps are as follows:
  1. gst-launch-1.0 uridecodebin uri=http:/xxx.m3u8 name=t ! queue ! audioconvert ! wavenc ! filesink location=./sink.wav t. ! queue ! videoconvert ! videoscale ! filesink location=./sink.h264
  2. use “ffprobe sink.wav” and “ffprobe sonyc_mixed_audio.wav” to check the format
  3. use audacity to convert
    pcm_f32le ([3][0][0][0] / 0x0003), 48000 Hz, 2 channels, flt
    to:
    pcm_s16le ([1][0][0][0] / 0x0001), 44100 Hz, 1 channels, s16
Maybe some conversion of audio is not supported?
Have you set nvstreammux property “live-source” to true for http source?
It says live-source is deprecated in streammux2 used in deepstream-audio.
https://docs.nvidia.com/metropolis/deepstream/dev-guide/text/DS_plugin_gst-nvstreammux2.html
Seems like streammux2 is designed to process audio frames. But I still cannot find the key issue about this bug.
Hi Fiona,
What do you say about the mixture of audio and video as caps.
Is this a bug which may cause the failure of pipeline?
No. There is no “mixture of audio and video as caps”. The video related log is involved by uridecodebin
I mean this part. The framerate, width and height are all about video, which should not exist in this flow of pure audio.
If this is ok, what is the problem. Any suggestion to debug?
We do not use separated audio plugin for inference, so it is OK. The plugin will ignore the video related caps fields when it handles the audio inferencing.
And you are right, current audio inference plugins only support mono S16LE audio data, Gst-nvstreammux New — DeepStream 6.1.1 Release documentation
I changed the format=S16LE along with rate=44100 within the capsfilter after audioresample.
There is still errors, no FPS and no prediction.
0:00:03.204888252 11045 0x5569b93030a0 WARN GST_PADS gstpad.c:4226:gst_pad_peer_query:<src_elem:src_0> could not send sticky events
0:00:03.205079607 11045 0x5569b93030a0 WARN v4l2videodec gstv4l2videodec.c:1673:gst_v4l2_video_dec_decide_allocation: Duration invalid, not setting latency
0:00:03.205130062 11045 0x5569b93030a0 WARN v4l2bufferpool gstv4l2bufferpool.c:1066:gst_v4l2_buffer_pool_start:nvv4l2decoder0:pool:src Uncertain or not enough buffers, enabling copy threshold
0:00:03.205619442 11045 0x5569b93036d0 WARN v4l2bufferpool gstv4l2bufferpool.c:1513:gst_v4l2_buffer_pool_dqbuf:nvv4l2decoder0:pool:src Driver should never set v4l2_buffer.field to ANY
0:00:03.206035067 11045 0x5569b92b7c50 WARN audio-resampler audio-resampler.c:274:convert_taps_gint16_c: can’t find exact taps
max_fps_dur 8.33333e+06 min_fps_dur 2e+08
0:00:03.206240931 11045 0x5569b92b7c50 WARN nvstreammux gstnvstreammux.cpp:742:configure_module:<src_bin_muxer> No config-file provided; falling back to default streammux config 1
0:00:03.212837544 11045 0x5569b92b7c50 WARN audioresample gstaudioresample.c:698:gst_audio_resample_check_discont:<audioresampler_elem> encountered timestamp discontinuity of 37408 samples = 0:00:00.779333333
**PERF: FPS 0 (Avg)
**PERF: 0.00 (0.00)
The log means the pipeline is working. Can you check your config file whether the “sync=0” is set in [sink] group?
