• Hardware Platform (Jetson / GPU) :GPU
• DeepStream Version :DeepStream-6.1.1
• Issue Type( questions, new requirements, bugs) :questions
I use nvurisrcbin to receive the H265 format RTSP stream, and use GST_deBUG=3 to display
error info:
rtph265depth gstrtph265depth. c: 1310: gst_rtp_h265_depay_process: Assuming DONL field is not present
Subsequently, my program reported a segment error
The code I am using:
static void cb_newpad(GstElement *decodebin, GstPad *decoder_src_pad, gpointer data)
GstCaps *caps = gst_pad_get_current_caps(decoder_src_pad);
if (!caps)
caps = gst_pad_query_caps(decoder_src_pad, NULL);
const GstStructure *str = gst_caps_get_structure(caps, 0);
const gchar *name = gst_structure_get_name(str);
GstElement *source_bin = (GstElement *)data;
GstCapsFeatures *features = gst_caps_get_features(caps, 0);
if (!strncmp(name, "video", 5))
if (gst_caps_features_contains(features, GST_CAPS_FEATURES_NVMM))
/* Get the source bin ghost pad */
GstPad *bin_ghost_pad = gst_element_get_static_pad(source_bin, "src");
if (!gst_ghost_pad_set_target(GST_GHOST_PAD(bin_ghost_pad), decoder_src_pad))
g_printerr("Failed to link decoder src pad to source bin ghost pad\n");
gst_object_unref(bin_ghost_pad);
else
g_printerr("Error: Decodebin did not pick nvidia decoder plugin.\n");
static void decodebin_child_added(GstChildProxy *child_proxy, GObject *object, gchar *name, gpointer user_data)
if (g_strrstr(name, "decodebin") == name)
g_signal_connect(G_OBJECT(object), "child-added", G_CALLBACK(decodebin_child_added), user_data);
if (g_strrstr(name, "source") == name)
g_object_set(G_OBJECT(object), "drop-on-latency", TRUE, NULL);
static GstElement *create_source_bin(guint index, gchar *uri, ReturnInfo *return_info)
GstElement *bin = NULL, *uri_decode_bin = NULL;
gchar bin_name[16] = {};
g_snprintf(bin_name, 15, "source-bin-%02d", index);
bin = gst_bin_new(bin_name);
uri_decode_bin = gst_element_factory_make("nvurisrcbin", "uri-decode-bin");
if (!bin || !uri_decode_bin)
g_log("Application-TGSD", G_LOG_LEVEL_INFO, "[ERROR] Failed to create the bin and uri_decode-bin in the created source");
return_info->is_success = 0;
strcpy(return_info->info, "Failed to create the bin and uri_decode-bin in the created source");
return NULL;
g_object_set(G_OBJECT(uri_decode_bin), "uri", uri, NULL);
g_object_set(G_OBJECT(uri_decode_bin), "rtsp-reconnect-interval", 30, NULL);
g_signal_connect(G_OBJECT(uri_decode_bin), "pad-added", G_CALLBACK(cb_newpad), bin);
g_signal_connect(G_OBJECT(uri_decode_bin), "child-added", G_CALLBACK(decodebin_child_added), bin);
gst_bin_add(GST_BIN(bin), uri_decode_bin);
if (!gst_element_add_pad(bin, gst_ghost_pad_new_no_target("src", GST_PAD_SRC)))
g_printerr("Failed to add ghost pad in source bin\n");
return NULL;
return bin;
Gst_debug=3 attachments
infer.txt (131.6 KB)
