I am experiencing a problem where deepstream will crash and return to the desktop without warning or message - it happens randomly: sometimes it will run for 24 hours without problem, but sometimes only a couple of hours before it crashes
I always get the same unity-panel-ser failed message in the syslog
I plan to change over to the latest version when I am able but I cannot do that at the moment.
Not least because I don’t have the unit with me, I only have remote access
Also I still need to investigate the process of converting from DS4 to 5, at the moment the program can be restarted immediately and it will run for a few hours before crashing. Removing the unit, converting to DS5 and reinstalling will cause major problems to the testing
whilst it is running the system is working well, if I use a tee the output logs from the app show no information. The log just stops with no error messages.
I’m not sure its deepstream that’s failing, I think its something else.
Maybe you can export GST_DEBUG=3 or 4 to enable more logs, more importantly, it’s better to use the latest DS and Jetpack. I guess upgrade Jetpack is useful if the error is from low-level libraries or kernel
Hey customer, we didn’t observe such issues, so cannot give some detailed guidance for how to fix it.
As I mentioned before, we won’t give patch for old version, so I would suggest to close this topic and create a new topic if the issue can repro on new DS version.
