Deepstream code works on video files but not on RTSP streams when ported to T4 GPU
• Hardware Platform (Jetson / GPU) : Tesla T4
• DeepStream Version : 7.1
• TensorRT Version :10.3
• CUDA Version :12.6
• NVIDIA GPU Driver Version (valid for GPU only) : 535
• Issue Type( questions, new requirements, bugs): Program works on video files but not on RTSP streams
I have a python deepstream code that runs fine on a Jetson Orin Nano. It could handle 15 cameras on that same program. We decided to instantiate a Virtual Machine on Azure to see how many cameras it can handle there but something strange happened. I got “Aborted (core dumped)” error when processing rtsp streams. I tried the same program with mp4 files and it worked fine. I tried it with just one rtsp stream. It doesn’t make sense for it to run out of resources. I running the code on a NGC Container with Deepstream 7.1 . My program can also connect to the RTSP stream with no problems.
Any ideas on what is causing this?I wonder if it is something I have to install to process rtsp streams on a T4 GPU.
what sample are you testing or referring to? what is the complete pipeline? can the following cmd run well?
gst-launch-1.0 uridecodebin uri=rtsp://"uri address"  ! fakesink
can this sample deepstream-test3 run well?
This is the code I am building by pipeline with
def cb_newpad(decodebin, decoder_src_pad, nvvidconv_in_bin):
    Callback function invoked when a new pad is added to the uridecodebin.
    It links the uridecodebin's new video source pad to the sink pad of the
    nvvideoconvert element provided in 'nvvidconv_in_bin' (user_data).
    print(f"In cb_newpad: Pad '{decoder_src_pad.get_name()}' added to '{decodebin.get_name()}'")
    caps = decoder_src_pad.get_current_caps()
    if not caps:
        print(f"Pad '{decoder_src_pad.get_name()}' has no current caps, querying...")
        caps = decoder_src_pad.query_caps()
    if not caps:
        sys.stderr.write(f"Error: Failed to get caps from pad '{decoder_src_pad.get_name()}' of element '{decodebin.get_name()}'.\n")
        return
    gststruct = caps.get_structure(0)
    gstname = gststruct.get_name()
    print(f"Pad '{decoder_src_pad.get_name()}' has caps: {caps.to_string()}, gstname = {gstname}")
    if "video" in gstname.lower():
        sink_pad_of_nvvidconv = nvvidconv_in_bin.get_static_pad("sink")
        if not sink_pad_of_nvvidconv:
            sys.stderr.write(f"Error: Unable to get sink pad of '{nvvidconv_in_bin.get_name()}'.\n")
            return
        if sink_pad_of_nvvidconv.is_linked():
            print(f"Info: Sink pad of '{nvvidconv_in_bin.get_name()}' is already linked. Unlinking before relinking.")
        print(f"Attempting to link '{decoder_src_pad.get_name()}' of '{decodebin.get_name()}' to sink of '{nvvidconv_in_bin.get_name()}'")
        link_result = decoder_src_pad.link(sink_pad_of_nvvidconv)
        if link_result != Gst.PadLinkReturn.OK:
            sys.stderr.write(f"Error: Failed to link pad '{decoder_src_pad.get_name()}' of '{decodebin.get_name()}' to sink pad of '{nvvidconv_in_bin.get_name()}'. Result: {link_result}\n")
        else:
            print(f"Successfully linked pad '{decoder_src_pad.get_name()}' of '{decodebin.get_name()}' to sink pad of '{nvvidconv_in_bin.get_name()}'")
    else:
        print(f"Info: Pad '{decoder_src_pad.get_name()}' is not a video pad (type: {gstname}). Skipping link.")
def decodebin_child_added(child_proxy, obj, name, user_data):
    Callback for 'child-added' signal of uridecodebin.
    Used to configure properties of internal elements like rtspsrc.
    print(f"Decodebin child added: '{name}' to element '{child_proxy.get_name()}' (obj type: {type(obj)})")
    if name.find("decodebin") != -1:
        obj.connect("child-added", decodebin_child_added, user_data)
    if "source" in name:
        if obj and obj.find_property('drop-on-latency') is not None:
            print(f"Setting 'drop-on-latency' to True for '{name}'")
            obj.set_property("drop-on-latency", True)
        elif obj and obj.find_property('latency') is not None:
             print(f"Setting 'latency' to 2000 for '{name}' (rtspsrc default can be high)")
             obj.set_property("latency", 2000)
def create_source_bin(index, uri):
    Creates a source bin for a given URI. This bin includes:
    uridecodebin -> nvvideoconvert -> videorate -> capsfilter (1 FPS, NVMM)
    Returns the Gst.Bin.
    print(f"Creating source bin for index {index}, URI: {uri}")
    bin_name = f"source-bin-{index:02d}"
    nbin = Gst.Bin.new(bin_name)
    if not nbin:
        sys.stderr.write(f"Error: Unable to create source bin '{bin_name}'.\n")
        return None
    # Create uridecodebin or nvurisrcbin based on file_loop
    if file_loop:
        uri_decode_bin = Gst.ElementFactory.make("nvurisrcbin", f"uri-decode-bin-{index}")
        if uri_decode_bin:
            uri_decode_bin.set_property("file-loop", True) # For nvurisrcbin, use True/False
            uri_decode_bin.set_property("cudadec-memtype", 0) # 0 for NVMM memory
        else:
            sys.stderr.write(f"Error: Unable to create nvurisrcbin for source {index}.\n")
            return None
    else:
        if not uri_decode_bin:
            sys.stderr.write(f"Error: Unable to create uridecodebin for source {index}.\n")
            return None
    uri_decode_bin.set_property("uri", uri)
    # Create the elements for frame rate control
    # These elements will be internal to the source bin
    nvvidconv_in_bin = Gst.ElementFactory.make("nvvideoconvert", f"nvvidconv-src-{index}")
    videorate_in_bin = Gst.ElementFactory.make("videorate", f"videorate-src-{index}")
    capsfilter_in_bin = Gst.ElementFactory.make("capsfilter", f"capsfilter-src-{index}")
    if not nvvidconv_in_bin or not videorate_in_bin or not capsfilter_in_bin:
        sys.stderr.write(f"Error: Failed to create conversion/rate elements for source_bin {index}.\n")
        return None
    # Configure the capsfilter for 1 FPS and NVMM memory
    caps_str = "video/x-raw(memory:NVMM), framerate=1/1"
    rate_caps = Gst.Caps.from_string(caps_str)
    capsfilter_in_bin.set_property("caps", rate_caps)
    print(f"Source bin {index}: capsfilter for 1FPS set to {caps_str}")
    # Add all elements to the bin
    nbin.add(uri_decode_bin)
    nbin.add(nvvidconv_in_bin)
    nbin.add(videorate_in_bin)
    nbin.add(capsfilter_in_bin)
    if not nvvidconv_in_bin.link(videorate_in_bin):
        sys.stderr.write(f"Error: Could not link nvvidconv to videorate in {bin_name}.\n")
        return None
    if not videorate_in_bin.link(capsfilter_in_bin):
        sys.stderr.write(f"Error: Could not link videorate to capsfilter in {bin_name}.\n")
        return None
    ghost_pad = Gst.GhostPad.new("src", capsfilter_in_bin.get_static_pad("src"))
    if not ghost_pad:
        sys.stderr.write(f"Error: Failed to create ghost pad in {bin_name}.\n")
        return None
    nbin.add_pad(ghost_pad)
    # Connect signals:
    uri_decode_bin.connect("pad-added", cb_newpad, nvvidconv_in_bin)
    uri_decode_bin.connect("child-added", decodebin_child_added, nbin)
    print(f"Successfully created source bin '{bin_name}' with 1 FPS processing.")
    return nbin
def create_pipeline(app_config):
    global log_file, stream_metadata, snapshot_writer
    log_file = app_config["output_log"]
    pgie_config_file = app_config["pgie_config"]
    batch_size = len(stream_configs)
    stream_metadata = {i: stream_configs[i] for i in range(batch_size)}
    # Initialize GStreamer
    Gst.init(None)
    pipeline = Gst.Pipeline.new("main-pipeline")
    if not pipeline:
        sys.stderr.write("Error: Unable to create Gst.Pipeline.\n")
        sys.exit(1)
    # nvstreammux
    streammux = Gst.ElementFactory.make("nvstreammux", "stream-muxer")
    if not streammux:
        sys.stderr.write("Error: Could not create nvstreammux.\n")
        sys.exit(1)
    streammux.set_property("batch-size", batch_size)
    streammux.set_property("batched-push-timeout", 40000)
    streammux.set_property("width", 1280)
    streammux.set_property("height", 720)
    streammux.set_property("live-source", 1 if any("rtsp://" in s["source"] for s in stream_configs) else 0) # Set if any RTSP streams
    pipeline.add(streammux)
    # Source bins
    for i, stream_conf in enumerate(stream_configs):
        uri = stream_conf["source"]
        print(f"Pipeline: Processing stream {i}: URI = {uri}")
        source_bin = create_source_bin(i, uri)
        if not source_bin:
            sys.stderr.write(f"Error: Failed creating source bin for stream {i}. Skipping this source.\n")
            continue
        pipeline.add(source_bin)
        # Request a sink pad from the streammuxer for this source
        muxer_sink_pad_template = streammux.get_pad_template("sink_%u")
        if not muxer_sink_pad_template:
            sys.stderr.write(f"CRITICAL Error: Unable to get sink pad template 'sink_%u' from nvstreammux.\n")
            sys.exit(1) # This is a fundamental issue with streammux setup
        requested_pad_name = f"sink_{i}"
        muxer_sink_pad = streammux.request_pad(muxer_sink_pad_template, requested_pad_name, None)
        if not muxer_sink_pad:
            sys.stderr.write(f"Error: Unable to request sink pad '{requested_pad_name}' from nvstreammux.\n")
            continue # Skip linking this source
        # Get the source pad from the source_bin (which is the ghost pad)
        bin_src_pad = source_bin.get_static_pad("src")
        if not bin_src_pad:
            sys.stderr.write(f"Error: Failed to get src ghost pad from source_bin '{source_bin.get_name()}'.\n")
        print(f"Pipeline: Linking src pad of '{source_bin.get_name()}' to sink pad '{muxer_sink_pad.get_name()}' of nvstreammux.")
        if bin_src_pad.link(muxer_sink_pad) != Gst.PadLinkReturn.OK:
            sys.stderr.write(f"Error: Failed linking source_bin '{source_bin.get_name()}' to nvstreammux pad '{muxer_sink_pad.get_name()}'.\n")
        else:
            print(f"Pipeline: Successfully linked source_bin '{source_bin.get_name()}' to nvstreammux sink_{i}.")
    # --- Downstream elements (PGIE, Tracker, etc.) ---
    pgie = Gst.ElementFactory.make("nvinfer", "primary-inference")
    tracker = Gst.ElementFactory.make("nvtracker", "tracker")
    nvvidconv_postmux = Gst.ElementFactory.make("nvvideoconvert", "nvvideo-converter-postmux")
    nvosd = Gst.ElementFactory.make("nvdsosd", "onscreendisplay")
    sink = Gst.ElementFactory.make("fakesink", "final-sink")
    # sink = Gst.ElementFactory.make("nveglglessink", "display_sink") # For actual display
    elements_to_add = [pgie, tracker, nvvidconv_postmux, nvosd, sink]
    element_names = ["pgie", "tracker", "nvvidconv_postmux", "nvosd", "sink"] # For error messages
    for idx, elem_factory_result in enumerate(elements_to_add):
        if not elem_factory_result:
            sys.stderr.write(f"Error: Unable to create element: {element_names[idx]}.\n")
            sys.exit(1)
        pipeline.add(elem_factory_result) # Add the actual element object
    # Configure PGIE
    pgie.set_property("config-file-path", pgie_config_file)
    # Configure Tracker from tracker.txt
    tracker_config_file_path = app_config['tracking_config']
    tracker_config_parser = configparser.ConfigParser()
    if not tracker_config_parser.read(tracker_config_file_path):
        sys.stderr.write(f"Warning: Could not read tracker config file: {tracker_config_file_path}\n")
    else:
        if 'tracker' in tracker_config_parser:
            for key, value in tracker_config_parser['tracker'].items():
                print(f"Tracker Config: Setting '{key}' to '{value}'")
                if key == 'tracker-width':
                    tracker.set_property('tracker-width', int(value))
                elif key == 'tracker-height':
                    tracker.set_property('tracker-height', int(value))
                elif key == 'gpu-id':
                    tracker.set_property('gpu-id', int(value))
                elif key == 'll-lib-file':
                    tracker.set_property('ll-lib-file', value)
                elif key == 'll-config-file':
                    tracker.set_property('ll-config-file', value)
                # Add other tracker properties as needed
        else:
            sys.stderr.write(f"Warning: 'tracker' section not found in {tracker_config_file_path}\n")
    # Link elements downstream of streammux
    print("Pipeline: Linking streammux -> pgie -> tracker -> nvvidconv_postmux -> nvosd -> sink")
    if not streammux.link(pgie): sys.exit("CRITICAL Error: Failed to link streammux to pgie.")
    if not pgie.link(tracker): sys.exit("CRITICAL Error: Failed to link pgie to tracker.")
    if not tracker.link(nvvidconv_postmux): sys.exit("CRITICAL Error: Failed to link tracker to nvvidconv_postmux.")
    if not nvvidconv_postmux.link(nvosd): sys.exit("CRITICAL Error: Failed to link nvvidconv_postmux to nvosd.")
    if not nvosd.link(sink): sys.exit("CRITICAL Error: Failed to link nvosd to sink.")
    # Attach buffer probes
    pgie_srcpad = pgie.get_static_pad("src")
    if not pgie_srcpad:
        sys.stderr.write("Error: Unable to get pgie src pad.\n")
    else:
        pgie_srcpad.add_probe(Gst.PadProbeType.BUFFER, snapshot_writer.roi_object_counts_probe)
        print("Pipeline: Added probe to PGIE src pad.")
    tracker_srcpad = tracker.get_static_pad("src")
    if not tracker_srcpad:
        sys.stderr.write("Error: Unable to get tracker src pad.\n")
    else:
        tracker_srcpad.add_probe(Gst.PadProbeType.BUFFER, snapshot_writer.update_tracking_data_probe)
        print("Pipeline: Added probe to Tracker src pad.")
    return pipeline
I can run the command
Somehow I run into this issue when executing that command
That is also weird because I don’t get this problem with the code I provided (maybe because I only link video sources with cb_newpad function) .
I tried this and didn’t have this problem
gst-launch-1.0 playbin uri=rtsp://rtsp_url
The code I provided is based on the deepstream-test3 part of creating components to read sources (functions in uridecode are practically equal). Besides, that code works for all situations when executed in the Jetson Orin Nano.
  1. about “It doesn’t make sense for it to run out of resources”? how did you observe it run out of resources? do you mean using the same code and one rtsp source, the applicaton still crashed? could you share the complete log? wondering wheather there are abnormal logs.
  2. please refer to my last comment. can test3 run well on the new device? Maybe there is some bug in the custom code. if test3 works well, you can compare the codes.
  3. could you narrow down this issue by simplifying the pipeline? for exmaple, you can check if “uridecodebin->nvstreammux->fakesink” works. Then check if “uridecodebin->nvstreammux->nvinfer->fakesink” works.
  1. I am getting the errors “Aborted:core dumped” and “Segmentation Fault” . I don’t think resources are running out.
    I also get this sometimes
  2. Deepstream-test3 worked fine with rtsp streams, I will try to find out the differences between the codes
  3. I tried to do that here, but got the same error.
I think it is some property I have to configure to run on T4. The error I get is the same in this simplified version.
from the error “unable to read the configuration”, it seems some configurations can’t be parsed. if test3 works well, you can compare the codes step by step. for example, you can check if “uridecodebin->nvstreammux->fakesink” works. Then check if “uridecodebin->nvstreammux->nvinfer->fakesink” works.
I found the problem. I decoupled the code that created the pipeline from the main function. Somehow when I merged both functions into one it worked…I have no idea why. The create pipeline function returned a pipeline object to the main function and that was it. There were also some global variables…Anyways, problem solved for now, thanks!
Glad to know you fixed it. Thanks for the update! If you need further support, please open a new one. Thanks!
