Dear forum, Dear nv-devs,
I’m really confused about the content of the deepstream base image. Its written here deepstream container docu that
Base: The DeepStream base container contains the plugins and libraries that are part of the DeepStream SDK along with dependencies such as CUDA, TensorRT, GStreamer, etc. This image is the recommended one for users that want to create docker images for their own DeepStream based applications. Please note that the base images do not contain sample apps or Graph Composer.
Reading this, I thought that e.g. cuda is part of the base image. However, it appears to be not. See this simple example
nvidia-docker run nvcr.io/nvidia/deepstream:6.0-devel /bin/sh -c "nvcc -V"
This will print out as expected:
Copyright (c) 2005-2021 NVIDIA Corporation
Built on Sun_Aug_15_21:14:11_PDT_2021
Cuda compilation tools, release 11.4, V11.4.120
Build cuda_11.4.r11.4/compiler.30300941_0
However, using the base image / samples-image:
nvidia-docker run nvcr.io/nvidia/deepstream:6.0-base "nvcc -V" # I also checked 6.1-base
nvidia-docker run nvcr.io/nvidia/deepstream:6.0-samples "nvcc -V"
returns:
/bin/sh: 1: nvcc: not found
Digging further, it appears that a lot of the binaries contained in the devel-image are not part of the base-image. Also the python versions seem to differ.
It does work when using the triton server however.
Am I misunderstanding something or is this an issue in the respective containers? Could you either fix the base images such that it’s more interchangeable with the devel-image? The current version makes it hard for me to develop anything based on the base-image.
Also there are no cuda binaries in base image
nvidia-docker run nvcr.io/nvidia/deepstream:6.0-base /bin/sh -c "ls /usr/local/cuda/bin"
ls: cannot access '/usr/local/cuda/bin': No such file or directory
Cheers
