Jetson Nano
• DeepStream Version
4.0.2
4.3
• TensorRT Version
6.0.1.10
I just installed a copy of Jetpack 4.3 on my nano and attempting to get deepstream working with camera source. With either deepstrem or nvgstcapture I get same errors in the log of nvargus-daemon. However when I capture video with nvgstcapture it works fine (other than the above errors), but in deepstream I begins to run and then segmentation fault. I have attached the logs for both.
Nvargus-daemon logs:
Jun 13 12:02:05 user nvargus-daemon[8754]: === NVIDIA Libargus Camera Service (0.97.3)=== Listening for connections...=== deepstream[8981]: Connection established (7FA63411D0)OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module0
Jun 13 12:02:05 user nvargus-daemon[8754]: OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module1
Jun 13 12:02:05 user nvargus-daemon[8754]: OFParserGetVirtualDevice: NVIDIA Camera virtual enumerator not found in proc device-tree
Jun 13 12:02:05 user nvargus-daemon[8754]: ---- imager: No override file found. ----
Jun 13 12:02:05 user nvargus-daemon[8754]: (NvCamV4l2) Error ModuleNotPresent: V4L2Device not available (in /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function findDevice(), line 256)
Jun 13 12:02:05 user nvargus-daemon[8754]: (NvCamV4l2) Error ModuleNotPresent: (propagating from /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function initialize(), line 60)
Jun 13 12:02:05 user nvargus-daemon[8754]: (NvOdmDevice) Error ModuleNotPresent: (propagating from dvs/git/dirty/git-master_linux/camera-partner/imager/src/devices/V4L2SensorViCsi.cpp, function initialize(), line 106)
Jun 13 12:02:05 user nvargus-daemon[8754]: NvPclDriverInitializeData: Unable to initialize driver v4l2_sensor
Jun 13 12:02:05 user nvargus-daemon[8754]: NvPclInitializeDrivers: error: Failed to init camera sub module v4l2_sensor
Jun 13 12:02:05 user nvargus-daemon[8754]: NvPclStartPlatformDrivers: Failed to start module drivers
Jun 13 12:02:05 user nvargus-daemon[8754]: NvPclStateControllerOpen: Failed ImagerGUID 1. (error 0xA000E)
Jun 13 12:02:05 user nvargus-daemon[8754]: NvPclOpen: PCL Open Failed. Error: 0xf
Jun 13 12:02:05 user nvargus-daemon[8754]: SCF: Error BadParameter: Sensor could not be opened. (in src/services/capture/CaptureServiceDeviceSensor.cpp, function getSourceFromGuid(), line 582)
Jun 13 12:02:05 user nvargus-daemon[8754]: SCF: Error BadParameter: (propagating from src/services/capture/CaptureService.cpp, function addSourceByGuid(), line 437)
Jun 13 12:02:05 user nvargus-daemon[8754]: SCF: Error BadParameter: (propagating from src/api/CameraDriver.cpp, function addSourceByIndex(), line 295)
Jun 13 12:02:05 user nvargus-daemon[8754]: SCF: Error BadParameter: (propagating from src/api/CameraDriver.cpp, function getSource(), line 458)
Jun 13 12:02:05 user nvargus-daemon[8754]: Acquiring SCF Camera device source via index 0 has failed. ---- imager: No override file found. ----
Jun 13 12:02:05 user nvargus-daemon[8754]: LSC: LSC surface is not based on full res!
Deepstream:
Opening in BLOCKING MODE
Creating LL OSD context new
Runtime commands:
h: Print this help
q: Quit
p: Pause
r: Resume
**PERF: FPS 0 (Avg)
**PERF: 0.00 (0.00)
** INFO: <bus_callback:189>: Pipeline ready
** INFO: <bus_callback:175>: Pipeline running
NvMMLiteOpen : Block : BlockType = 4
===== NVMEDIA: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 4
GST_ARGUS: Creating output stream
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 3264 x 2464 FR = 21.000000 fps Duration = 47619048 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
CONSUMER: Waiting until producer is connected...
GST_ARGUS: 3264 x 1848 FR = 28.000001 fps Duration = 35714284 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1920 x 1080 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 59.999999 fps Duration = 16666667 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 120.000005 fps Duration = 8333333 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: Running with following settings:
Camera index = 0
Camera mode = 0
Output Stream W = 3264 H = 2464
seconds to Run = 0
Frame Rate = 21.000000
GST_ARGUS: PowerService: requested_clock_Hz=627200000
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
H264: Profile = 66, Level = 0
