• Hardware Platform (Jetson / GPU) dGPU
• DeepStream Version 6.0.1
• TensorRT Version8.0.1
**• NVIDIA GPU Driver Version (valid for GPU only)**510.47.03
I have been recently developing a face-blurring pipeline, and have had success. testing basic videos works fine.
The pipeline is developed and run inside the ‘6.0.1-triton’ container from nvidia, using python bindings.
though when testing a different sample video, one with many detectable faces, i recieve this error a couple of seconds into the video;
[ ERROR: CUDA Runtime ] an illegal memory access was encountered
[WARN ] 2022-08-07 04:28:31 (cudaErrorIllegalAddress)
GPUassert: an illegal memory access was encountered src/modules/NvMultiObjectTracker/context.cpp 197
ERROR: [TRT]: 1: [convolutionRunner.cpp::checkCaskExecError::440] Error Code 1: Cask (Cask Convolution execution)
ERROR: [TRT]: 1: [apiCheck.cpp::apiCatchCudaError::17] Error Code 1: Cuda Runtime (an illegal memory access was encountered)
ERROR: nvdsinfer_backend.cpp:310 Failed to enqueue inference batch
ERROR: nvdsinfer_context_impl.cpp:1643 Infer context enqueue buffer failed, nvinfer error:NVDSINFER_TENSORRT_ERROR
0:00:03.660359605 2431 0x3583980 WARN nvinfer gstnvinfer.cpp:1324:gst_nvinfer_input_queue_loop: error: Failed to queue input batch for inferencing
terminate called without an active exception
ERROR: nvdsinfer_context_impl.cpp:341 Failed to make stream wait on event, cuda err_no:700, err_str:cudaErrorIllegalAddress
ERROR: nvdsinfer_context_impl.cpp:1619 Preprocessor transform input data failed., nvinfer error:NVDSINFER_CUDA_ERROR
0:00:03.660521480 2431 0x3583980 WARN nvinfer gstnvinfer.cpp:1324:gst_nvinfer_input_queue_loop: error: Failed to queue input batch for inferencing
Aborted (core dumped)
Using nvidia-smi while running the application shows that on at most, 2640MiB / 6144MiB gpu memory is used.
The pipeline is running using nvbuf-memory-type = NVBUF_MEM_CUDA_UNIFIED on all ‘nvvideoconvert’ components.
Any help with this would be appreciated
