Hello, I’m trying to deep copy the frame meta so that it doesn’t get overwritten when a new buffer arrives while another thread is processing it. A segmentation error occurs when I use the nvds_copy_frame_meta function to copy the frame meta. You can reproduce the code by iterating through frames and attempting to deep copy frame meta in deepstream test 3.
I’d like to extract the data contained within the metadata in order to generate JSON data. When I try to pass obj meta list in a struct and process it in another threat with data from the queue, I get a segmentation error when I try to access its values. When I iterate through its values in the main thread, this does not happen.
This one works without any problem. But it’s slow.
There is no update from you for a period, assuming this is not an issue any more. Hence we are closing this topic. If need further support, please open a new one. Thanks
