• Hardware Platform: GPU
• DeepStream Version: 7.1
• TensorRT Version: 10.3.0.26-1+cuda12.5
• NVIDIA GPU Driver Version: 560.35.05-0ubuntu1
• Issue Type: questions
• How to reproduce the issue ? Source code is provided
I’m experiencing severe issues when scaling my DeepStream pipeline from 5 video sources to 15+ sources. The pipeline works flawlessly with fewer sources but has these random behavior with more sources:
Inconsistent Detection Results: When running the same video on all sources, same tracked objects (cars) produce different detection outputs
@staticmethod
def sgie2_detection_probe(
pad, info: Gst.PadProbeInfo, detection_storage: dict, dict_lock: Lock
Probe to build dictionary out of the detections, and save it to a temporary buffer
gst_buffer = info.get_buffer()
if not gst_buffer:
return Gst.PadProbeReturn.OK
gst_buffer_hash = hash(gst_buffer)
batch_meta = pyds.gst_buffer_get_nvds_batch_meta(gst_buffer_hash)
if not batch_meta:
l_frame = batch_meta.frame_meta_list
while l_frame is not None:
try:
except StopIteration:
break
if frame_meta.num_obj_meta:
frame_data = DeepStream.build_object_hierarchy(frame_meta)
key = f"{frame_meta.source_id}_{frame_meta.frame_num}"
with dict_lock:
detection_storage[key] = frame_data
try:
l_frame = l_frame.next
break
@staticmethod
def jpeg_encoder_probe(
pad,
frame_data_queue: multiprocessing.Queue,
dict_lock: Lock,
Probe after JPEG encoder that retrieves detection data and combines with encoded image.
if detection_storage.values().__len__() > 10:
print(detection_storage.values().__len__(), end="\r")
if not gst_buffer:
# Extract JPEG binary data
success, map_info = gst_buffer.map(Gst.MapFlags.READ)
if not success:
jpeg_data = bytes(map_info.data)
gst_buffer.unmap(map_info)
# Get batch meta to access frame meta
if not batch_meta:
try:
break
try:
# Get frame_data from storage using unique key
with dict_lock:
frame_data = detection_storage.pop(key, None)
if frame_data:
frame_data["frame_info"]["frame"] = jpeg_data
frame_data_queue.put(frame_data)
except Exception as e:
print(f"Error processing frame_meta in encoder probe: {e}")
try:
break
Questions
Is there a way to access SGIE1 and SGIE2 detection results directly in the JPEG encoder probe? Currently, the metadata seems stripped or unavailable at that stage. If not, would using NvDsUserMeta or NvDsFrameMeta’s user_meta_list be more reliable for passing detection data through the pipeline?
Any insights on proper metadata synchronization in multi-source DeepStream pipelines would be greatly appreciated. The core question is: How can I reliably associate SGIE detection results with their corresponding encoded frames when scaling to 15+ sources?
I added nvstreamdemux after tee and now the detected bounding boxes alignment is fixed, however when the number of video sources is increased to about 11, it prints the following logs and gives 0 fps.
Warning: gst-stream-error-quark: Could not demultiplex stream. (9): ../gst/avi/gstavidemux.c(4088): gst_avi_demux_stream_header_pull (): /GstPipeline:pipeline0/GstBin:source-bin-03/GstDsNvUriSrcBin:uri-decode-bin/GstURIDecodeBin:nvurisrc_bin_src_elem/GstDecodeBin:decodebin3/GstAviDemux:avidemux2:
failed to parse stream, ignoring
Warning: gst-stream-error-quark: Could not demultiplex stream. (9): ../gst/avi/gstavidemux.c(4088): gst_avi_demux_stream_header_pull (): /GstPipeline:pipeline0/GstBin:source-bin-04/GstDsNvUriSrcBin:uri-decode-bin/GstURIDecodeBin:nvurisrc_bin_src_elem/GstDecodeBin:decodebin4/GstAviDemux:avidemux1:
(python:465547): GStreamer-Base-CRITICAL **: 15:26:27.555: gst_flow_combiner_update_pad_flow: assertion 'pad != NULL' failed
(python:465547): GStreamer-Base-CRITICAL **: 15:26:27.556: gst_flow_combiner_update_pad_flow: assertion 'pad != NULL' failed
(python:465547): GStreamer-Base-CRITICAL **: 15:26:27.557: gst_flow_combiner_update_pad_flow: assertion 'pad != NULL' failed
Failed to query video capabilities: Invalid argument
Decodebin child added: nvurisrc_bin_queue
Decodebin child added: nvurisrc_bin_nvvidconv_elem
Decodebin child added: nvurisrc_bin_src_cap_filter_nvvidconv
In cb_newpad
gstname= video/x-raw
features= <Gst.CapsFeatures object at 0x74894b901de0 (GstCapsFeatures at 0x74879002fc20)>
In cb_newpad
features= <Gst.CapsFeatures object at 0x74894b901900 (GstCapsFeatures at 0x7487600042c0)>
**PERF : FPS_1 (0.00) FPS_9 (0.00) FPS_11 (0.00)
It’s local avi video files. I’m using nvurisrcbin from deepstream-test3. These logs don’t get generated with fewer sources. Can you check out the provided source code please?
I meant I am using the same approach as deepstream-test3 for adding multiple sources(local file or rtsp)
I have actually referred to the deepstream-demux-multi-in-multi-out sample. Unfortunately there’s no sample with tee + nvstreamdemux elements together.
If you could check out the code, do I actually need the tee? Can’t I directly get the encoded frames in a straight-forward pipeline? Essentially the goal is to show the output and get the JPEG encoded frames via probe functions simultaneously.
No, actually I don’t need every single frame. I’m running DeepStream via this module on a separate process and put detections along with encoded frame into a shared multiprocessing.Queue to handle them in my main logic process. I only need the best frame per each tracked object and I decide which frame is the best in my main logic process.
It would actually be a lot more efficient if I could selectively encode the best frames, but I couldn’t figure out a way to communicate the encode signal between these two processes in real-time.
Your main logic process needs every frame and its corresponding detections be available to make the decision that which frames are the best frames, right?
You can refer to the save image part and insert pad probe function with nvstreamdemux output, please make sure you need to add nvvideoconvert to convert the video format to RGBA after nvstreamdemux for JPEG encoding. And you app can design any API to communicate between your main logic process and the probe function.
I have already tried get_nvds_buf_surface to get the raw frame data and convert it to numpy array, but it had a very bad impact on the performance.
I also tried encoding the frame using nvds_obj_enc_process within a probe function and then retrieving the encoded frame further along the pipeline via another probe function. However, due to its asynchronous nature, the second probe function did not always return the encoded frame.
So far nvjpegenc has performed the best for my case, and I haven’t seen any significant performance degradation. I’d appreciate it if you could help me set up the current approach correctly.
