• Hardware Platform (Jetson / GPU) AGX
• DeepStream Version 5.1
• JetPack Version (valid for Jetson only) 4.3
• TensorRT Version 7.1
• NVIDIA GPU Driver Version (valid for GPU only) 10.2
when i add two rtsp stream on deepstream-app, when the two sources is valid it work well, but when one is valid and
the another is invalid , deepstream can not work well on the valid stream , there is no stream output.
Can you upload the log with error?
Fri Aug 27 18:00:43 2021
**PERF: 0.00 (1.07) 0.00 (0.00)
Fri Aug 27 18:00:48 2021
**PERF: 0.00 (0.72) 0.00 (0.00)
Fri Aug 27 18:00:53 2021
**PERF: 0.00 (0.54) 0.00 (0.00)
Fri Aug 27 18:00:58 2021
**PERF: 0.00 (0.43) 0.00 (0.00)
Fri Aug 27 18:01:03 2021
**PERF: 0.00 (0.36) 0.00 (0.00)
Fri Aug 27 18:01:08 2021
**PERF: 0.00 (0.31) 0.00 (0.00)
Fri Aug 27 18:01:13 2021
**PERF: 0.00 (0.27) 0.00 (0.00)
Fri Aug 27 18:01:18 2021
**PERF: 0.00 (0.24) 0.00 (0.00)
Fri Aug 27 18:01:23 2021
**PERF: 0.00 (0.22) 0.00 (0.00)
Fri Aug 27 18:01:28 2021
**PERF: 0.00 (0.20) 0.00 (0.00)
Fri Aug 27 18:01:33 2021
**PERF: 0.00 (0.18) 0.00 (0.00)
** WARN: <watch_source_status:614>: No data from source 0 since last 60 sec. Trying reconnection
** INFO: <reset_source_pipeline:1155>: Resetting source 0
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
Opening in BLOCKING MODE
** INFO: <reset_source_pipeline:1155>: Resetting source 1
Fri Aug 27 18:01:38 2021
**PERF: 0.03 (0.20) 0.00 (0.00)
ERROR from src_elem1: Could not open resource for reading and writing.
Debug info: gstrtspsrc.c(7469): gst_rtspsrc_retrieve_sdp (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin1/GstRTSPSrc:src_elem1:
Failed to connect. (Generic error)
This is my test log, you can reproduce this problem simply.
Hi Fiona,
have you reproduce the problem ?
Hi,have you solved this problem ?
Not yet, I dont konw how to resolve the problem. I need nvidia’s help.
Amycao
September 7, 2021, 1:56am
8
HI,
I can not repro your issue. by providing one valid rtsp camera, one invalid rtsp camera, it run well. did not report
Did you use original sample or your own?
**PERF: FPS 0 (Avg) FPS 1 (Avg)
**PERF: 0.00 (0.00) 0.00 (0.00)
** INFO: <bus_callback:181>: Pipeline ready
ERROR from src_elem1: Unhandled error
Debug info: gstrtspsrc.c(6161): gst_rtspsrc_send (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin1/GstRTSPSrc:src_elem1:
Internal Server Error (500)
** INFO: <reset_source_pipeline:1433>: Resetting source 1
**PERF: 25.09 (25.06) 0.00 (0.00)
**PERF: 24.91 (24.92) 0.00 (0.00)
**PERF: 24.90 (24.95) 0.00 (0.00)
**PERF: 24.90 (24.91) 0.00 (0.00)
**PERF: 24.90 (24.93) 0.00 (0.00)
**PERF: 24.90 (24.90) 0.00 (0.00)
**PERF: 24.90 (24.92) 0.00 (0.00)
**PERF: 24.89 (24.90) 0.00 (0.00)
**PERF: 24.89 (24.91) 0.00 (0.00)
**PERF: 24.91 (24.90) 0.00 (0.00)
q
