• Hardware Platform :GPU
• DeepStream Version :5.1
• TensorRT Version:7.2
• language: python3.6
• camera IP: Hikvision
Hi.everyone
I am using deepstream to inference multi-rtsp-source in python.
When i input error password of rtsp and dynamic changge source ,got error(message.type) in the bus_call (callback function)
bus_call callback function
def bus_call(bus, message, loop,queue):
t = message.type
if t == Gst.MessageType.EOS:
sys.stdout.write("End-of-stream\n")
loop.quit()
elif t==Gst.MessageType.WARNING:
err, debug = message.parse_warning()
sys.stderr.write("Warning: %s: %s\n" % (err, debug))
elif t == Gst.MessageType.ERROR:
err, debug = message.parse_error()
sys.stderr.write("Error: %s: %s\n" % (err, debug))
print(message.src.name)
print("\n","*"*20)
print("info",message,type(message))
print("error",err,type(err))
print("debug",debug,type(debug))
print("*"*20,"\n")
queue.put(debug) # message queue
if "Option not supported (551)" in debug :
pass # dynamic change rtsp source
elif "Unauthorized (401)" in debug:
pass # error of rtsp
else:
print("[ WARNING ] Exiting app \n")
loop.quit()
return True
problem 1. input error of rtsp
log
info <Gst.Message object at 0x7f100c114f48 (GstMessage at 0x7f0e7400a4a0)> <class ‘gi.repository.Gst.Message’>
error gst-resource-error-quark: Unauthorized (15) <class ‘GLib.GError’>
debug gstrtspsrc.c(6116): gst_rtspsrc_send (): /GstPipeline:pipeline0/GstURIDecodeBin:source-bin-00/GstRTSPSrc:source:
Unauthorized (401) <class ‘str’>
to resolve this problem
def add(uri,id): #uri is rtsp , id is source_$(id)
source_bin = create_uridecode_bin(id,uri) #
source_bin_list[id]=source_bin
pipeline.add(source_bin)
state = source_bin_list[id].set_state(Gst.State.PLAYING)
print(" [INFO] ",state)
time.sleep(0.2) # wait queue_mes of call_bus for 0.2 s
if queue_mes.full() == True: # get error info from queue_mes
error_msg = queue_mes.get().split("\n")[1]
if error_msg == "Unauthorized (401)":
source_bin_list[id].set_state(Gst.State.NULL) # set the state of source_bin from PLAYING to NULL
pipeline.remove(source_bin_list[id]) # The sourece_bin encountered an error at runtime and dose not call the callback function (decodebin_child_added,cb_newpad),so remove the source_bin from pipeline directly
source_bin_list[id] = None
print("401 remove")
when i the add error of rtsp,then pipeline cannot add other source
problem 2. dynamic change source
when i delete rtsp source , gstreamer get an error , from other topic get resolution, annotation loop.quit()
but then pipeline cannot add other source
conclusion
The pipeline can not add the any rtsp source if pipeline encountered an error at running
