@AastaLLL I got past this error which was actually due to rebuilding TensorRT and the pre-installed TensorRT that came with JetPack 4.5.1 worked out fine. I re-did all the above steps and got the following successful inference.
ds-tao-segmentation -c ~/Desktop/optimisation/deepstream_tao_apps/customConfigs/custom_config.txt -i ~/Desktop/optimisation/large.jpg
Now playing: /home/virus/Desktop/optimisation/deepstream_tao_apps/customConfigs/custom_config.txt
Opening in BLOCKING MODE
0:00:03.762353419 10172 0x55905e4040 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1702> [UID = 1]: deserialized trt engine from :/home/virus/Desktop/optimisation/res101-holygrail-ep26-fp16.engine
INFO: [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input_image 3x1024x1024
1 OUTPUT kFLOAT mrcnn_detection 100x6
2 OUTPUT kFLOAT mrcnn_mask/Sigmoid 100x4x28x28
0:00:03.762579860 10172 0x55905e4040 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1806> [UID = 1]: Use deserialized engine model: /home/virus/Desktop/optimisation/res101-holygrail-ep26-fp16.engine
0:00:03.899089690 10172 0x55905e4040 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<primary-nvinference-engine> [UID 1]: Load new model:/home/virus/Desktop/optimisation/deepstream_tao_apps/customConfigs/custom_config.txt sucessfully
Running...
NvMMLiteBlockCreate : Block : BlockType = 256
[JPEG Decode] BeginSequence Display WidthxHeight 1024x1024
in videoconvert caps = video/x-raw(memory:NVMM), format=(string)RGBA, framerate=(fraction)1/1, width=(int)1280, height=(int)720
End of stream
Returned, stopping playback
[JPEG Decode] NvMMLiteJPEGDecBlockPrivateClose done
[JPEG Decode] NvMMLiteJPEGDecBlockClose done
Deleting pipeline
But the mask saved is all black. My config file is as follows:
[property]
gpu-id=0
net-scale-factor=0.007843
# Since the model input channel is 3, using RGB color format.
model-color-format=0
offsets=127.5;127.5;127.5
labelfile-path=./custom_labels.txt
##Replace following path to your model file
model-engine-file=/home/virus/Desktop/optimisation/res101-holygrail-ep26-fp16.engine
#DS5.x cannot parse onnx etlt model, so you need to
#convert the etlt model to TensoRT engine first use tao-convert
tlt-encoded-model=../../models/peopleSemSegNet/peoplesemsegnet.etlt
tlt-model-key=tlt_encode
infer-dims=3;1024;1024
##3;544;960
batch-size=1
## 0=FP32, 1=INT8, 2=FP16 mode
network-mode=2
num-detected-classes=4
interval=0
gie-unique-id=1
network-type=2
output-blob-names=mrcnn_mask/Sigmoid
segmentation-threshold=0.0
##specify the output tensor order, 0(default value) for CHW and 1 for HWC
segmentation-output-order=1
[class-attrs-all]
roi-top-offset=0
roi-bottom-offset=0
detected-min-w=0
detected-min-h=0
detected-max-w=0
detected-max-h=0
Note that I have no tlt model and simply leave the
The mask are all black indicates that there are nothing detected.
Just check your configuration, could you valid if net-scale-factor and offsets are correct?
It is common that an incorrect data range leads to the detector malfunction.
$ cd deepstream_4.x_apps/nvdsinfer_customparser_mrcnn_uff/
$ CUDA_VER=10.2 make
$ cd ../
$ make
$ cp {res101-holygrail-ep26.uff} mrcnn_nchw.uff
$ ./deepstream-custom pgie_mrcnn_uff_config.txt /opt/nvidia/deepstream/deepstream-6.0/samples/streams/sample_720p.h264
I don’t understand why do you rename the uff file. Does this sample automatically search for mrcnn_nchw.uff and create an engine file out of it ? cp {res101-holygrail-ep26.uff} mrcnn_nchw.uff
even though we explicitly mention our engine +model-engine-file=./mrcnn_nchw.uff_b1_gpu0_fp32.engine
I can see the custom_parser compiled in the MAKEFILE provided within the directory and it replaces the default parser by specifying in pgie_mrcnn_uff_config.txt. But I fail to find any reference to the custom parser being used post-inference, defined anywhere in the deepstream_custom.c.
Ok so after studying GStreamer, I understand that the custom parser is simply an element in the entire pipeline, created by parsing the pgie config file. The following snapshot explains how it connects to the rest of the pipeline.
Screenshot 2022-01-17 at 3.09.48 PM
Hey @AastaLLL sorry to bring this up again even though this issue is resolved.
Just wanted to confirm if during your test, were you able to overlay the mask on the result ? In my case, all I get it the bounding box. I am aware that there are methods to save the mask from within the parser’s script but is there any other way that you used ?
