DeepStream dynamically delete source
Pipeline
rtspsrc,rtph264depay,nvv4l2decoder \ ----------------------------------------------/rtmpsinkbin
rtspsrc,rtph264depay,nvv4l2decoder – > streammux,pgie, nvtracker, streamdemux, rtmpsinkbin
rtspsrc,rtph264depay,nvv4l2decoder /----------------------------------------------\rtmpsinkbin
when I set rtspsrc element state:
GstStateChangeReturn state_return = gst_element_set_state (srcbin[i].rtspsrc, GST_STATE_NULL);
I got error from bus_call:
ERROR from element rtsp-src: Unhandled error
Error details: gstrtspsrc.c(6161): gst_rtspsrc_send (): /GstPipeline:pipeline/GstRTSPSrc:rtsp-src:
Option not supported (551)
But state_return is return as GST_STATE_CHANGE_SUCCESS
Why
• DeepStream Version 5.0dp
• TensorRT Version 7
You may replace rtmpsinkbin with fakesink and try again. To make sure the issue is not triggered by rtmpsink.
And can try to launch RTP server through test-launch:
sudo apt-get install libgstrtspserver-1.0 libgstreamer1.0-dev
gcc test-launch.c -o test-launch $(pkg-config --cflags --libs gstreamer-1.0 gstreamer-rtsp-server-1.0)
[test-launch.c download from: https://github.com/GStreamer/gst-rtsp-server/blob/master/examples/test-launch.c]
./test-launch "filesrc location=sample_1080p_h264.mp4 ! qtdemux ! rtph264pay name=pay0 pt=96 "
To clarify if the issue is specific to the RTSP source.
replace rtmpsinkbin with fakesink: result is same error
use test-launch … : result is OK
but camera is hikvision ,everything is ok
How can I fix this bug ?
We have a sample for dynamically add/delete sources:
Please refer to it for your implementation.
I know this repo and test . will occur same error
It is solved by rtspssrc source code
Good to know you have fixed it. Thanks.
could you tell me how slove it? thank you
